Default Clutch Linkage: Release rod and adjuster problems
Old 06-04-2018, 03:20 PM   #1
Jslampe is offline
Jslampe
Vehicle(s): '83 CJ7 258 5pd D300
Rep Power: 0 Jslampe is on a distinguished road
If youíve been following at home, I had a couple problems with my clutch linkage (driver side pivot bracket sheared off the bolts). Upon review of the linkage, bell crank, etc., it looked pretty rough so I ordered a whole new kit for $70. (Before you ask, no I didnít get the Heim upgrade. Will eventually. Need several other parts in the original kit.)
http://repairguide.autozone.com/znet...528004b223.gif
The problem Iím having now, is with the Release Rod/Adjuster and/or the Throwout Lever. Even at their shortest setting, the Release Rod + Adjuster are far too long. When I placed them in the the Throwout bracket, the RR+Adj was a solid 1 inch too long creating a healthy gap between the Inner Support Bracket and the transmission casing (where the bolts go).
Illustrations to (maybe help):
https://drive.google.com/drive/folde...hf?usp=sharing
The most confusing part is comparing the old Release Rod and Adjuster withe new oneÖ Theyíre the EXACT same size as the new one! WTF am I doing wrong?
Furthermore, Throwout Lever wonít move by hand like Iíd assumed it wouldíve. I know the Transmission is fine-ish. When the linkage broke I was able to jimmy-rig a fix with a piece of wood and drive it up the driveway into the garage.
I feel like an idiot, but thereís got to be something Iím missing. IíM SO CLOSE
Default Re: Clutch Linkage: Release rod and adjuster problems
Old 06-04-2018, 03:47 PM   #2
jp360cj is offline
jp360cj
Bolt the bracket to the transmission before you try to put the adjuster rod into the fork. The adjuster should adjust at both ends, so if you bottomed out 1 side, adjust the other side in. The shift fork should have a little movement by hand, but not much. You are pushing against some pretty strong springs on the pressure plate.
Old 06-04-2018, 04:05 PM   #3
Jslampe is offline
Jslampe
Super helpful context on the plates. That makes sense, but the fork will not budge... It could be a matter of leverage so I'll give it a go, again, when I get home.
I've shortened it at both ends. Neither the top portion (which goes into the bellcrank bracket) or the bottom portion (which goes into throwout lever) will shorten anymore. Again, will try again when I get home.
Wondering if I'm doing these the wrong order?
As I see it, thereís 4 points of contact:
1. The outer pivot bracket into the bell crank
2. The driverís side part of the bellcrank that connects to the linkage.
3. The inner pivot bracket into the bell crank (currently not bolted in)
4. The adjusterís physical point of contact into the throwout leverís bracket.
I started with the #1, then #2, and now canít get #3 or #4. Maybe I should start in reverse order?
Old 06-04-2018, 04:36 PM   #4
jp360cj is offline
jp360cj
It shouldn't matter which end of the bellcrank you bolt on first. I just did this yesterday and put both brackets on the bellcrank, then bolted the clutch pedal side in because it had studs and was easiest. Then I bolted the bellhousing side, then the adjuster.
Looking at your sketch, are the bellhousing bolts too far to the rear or too far up/down/left right? Do you have a body lift or t-case drop?
Old 06-04-2018, 05:04 PM   #5
Jslampe is offline
Jslampe
Yeah, that sketch may be misleading as the bellhousing bolts run passenger-to-driver side. Right now, they're too far to the left (i.e. passenger side). Need them to come more to the driver side.
No body lift and I'm fairly certain there's no transfer case drop on it.
I'd also add that, when I did have the bellcrank put on, it was level.
Old 06-04-2018, 08:43 PM   #6
Jslampe is offline
Jslampe
I retract that statement. It's not passenger-side to driver-side. It's what JP360jeep said. The gap is rear-to-front, with the bracket missing the bellhousing holes by one inch. Taking pictures. Will report back soon.
Man, I wish there was an easier way to upload pictures from my phone in this forum.
Old 06-05-2018, 06:14 AM   #7
jp360cj is offline
jp360cj
Download the Tapatalk app. You can easily upload pictures from your phone with it.
Old 06-05-2018, 09:48 AM   #8
Jslampe is offline
Jslampe
Will do.
Quick update: I think I figured out the problem. The outer (driverís side) support pivot bracket is back about an inch farther back (towards rear) than it should be. I think this is due to an accident it apparently had in the late 80s (the front left fender had ďhit a fence at an odd angleĒ). This has created a slight angle ď\Ē from the outer to inner bracket and would explain why the pivot bracket bolts heard off 20-years later.
QUESTION: Whatís the best way to shore up/shim this gap? 3-4 washers? What type of washer should I use (e.g. fender? Flat? Rubber?)? That area will undergo some serious himming and hawing with the roads leading to my house.
adjuster , cj7 , clutch , clutch linkage , linkage , pivot bar , problems , release , rod
shudder on clutch release JTNCHRIS Drivetrain 26 05-13-2014 09:28 PM
Clutch linkage kerryfryer Suspension and Steering 11 08-15-2012 11:53 AM
Bell crank clutch release backwards 1984 CJ7 Drivetrain 5 07-08-2012 12:53 PM
Clutch Adjuster larry83 Drivetrain 13 02-11-2012 10:37 AM
