Default Re: Clutch linkage confusion 84 CJ7
Old 01-04-2020, 02:16 PM   #21
mitchelllogic is offline
mitchelllogic
Vehicle(s): 1982 CJ7 Returned to stock (Sold), 2002 Jeep Cherokee Sport stock (Sold), 1985 CJ7 - Restomod
mitchelllogic's Avatar
Rep Power: 6 mitchelllogic is on a distinguished road
Originally Posted by Patrick View Post
Novak’s kit is flawless. Had it for five years, zero issues. If only they made a matching high quality master cylinder...
I do remember they offer two volume sizes to select pedal effort , f I am correct, or to match master cylinder, not sure.
No doubt! I was excited when i.pulled the slave from the box, loved the braided tube, then was a little disappointed when I unpackaged the master.
Works good though.
Sent from my Pixel 2 using Tapatalk
Old 01-04-2020, 02:19 PM   #22
mitchelllogic
Originally Posted by bender3 View Post
Well, I'll be starting from scratch. I will be doing the project on a CJ with a YJ tub.
I've never done this mod before, so if anyone has any tips or tricks for the pedal to master connection, that would be great too.
I can take photos of my setup if you like. Mines a CJ W/YJ Tub as well. With a TJ Soft Top!
Let me know what you want photos of.
Thumbs up Re: Clutch linkage confusion 84 CJ7
Old 01-04-2020, 08:11 PM   #23
bender3 is offline
bender3
Vehicle(s): 81 CJ7, .258, SR4 (boo), D300,
Rep Power: 0 bender3 is on a distinguished road
[QUOTE=mitchelllogic;277249]I can take photos of my setup if you like. Mines a CJ W/YJ Tub as well. With a TJ Soft Top!
If you could get a few shots of the pedal connection, that would be great. I've never done this one before.
Old 01-05-2020, 05:22 PM   #24
JeeperChris is offline
JeeperChris
JeeperChris's Avatar
I didn't see the link for the Novak kit yet. Here's the link, and the options were for a 3/4 or 7/8 bore size. This is on my list to do also, but hopefully I'll have a glass CJ tub.
https://www.novak-adapt.com/catalog/...-hcr3/kit-hcra
Old 01-05-2020, 05:24 PM   #25
mitchelllogic
Used the existing pedal assembly. Used the washer to see where the hole would line up. Held it up to the pedal stop arm and centered it on the width of the clutch pedal arm. Turns out it located exactly where it needed to be.
Used a shoulder bolt and cut to length (on the bench with a nut on the bolt so you can fix the cut thread).
Double nut on the backside to lock it worked better than lock washers etc.
The Following User Says Thank You to mitchelllogic For This Useful Post:
bender3 (01-07-2020)
Old 01-05-2020, 05:27 PM   #26
JeeperChris
Did you put the hole through the pedal arm or was it already there?
The Following User Says Thank You to JeeperChris For This Useful Post:
Old 01-05-2020, 05:28 PM   #27
mitchelllogic
I drilled the hole. Based it on the size of the eye on the master cylinder.
JeeperChris (01-05-2020)
Old 01-05-2020, 06:32 PM   #28
cleg is offline
cleg
Vehicle(s): 1984 CJ7, 258 L6 4 spd manual, recent purchase 1977 CJ7 304 V8, 3spd, sold. Currently own; 2001 TJ Wrangler 2009 JK 2-door Wrangler 1972 FJ40 Landcruiser 2014 Toyota FJ Cruiser 2008 Nissan Pathfinder 4x4 2018 Nissan Titan 4x4 1928 Chrysler 1950 Plymouth Other jeeps... 1995 Jeep XJ Cherokee sold 1996 Jeep Cherokee XJ sold 1987 YJ Wrangler sold
Rep Power: 0 cleg is on a distinguished road
Originally Posted by GTOgoat View Post
I had the same problem, I put in new linkage and the adjustable rod connected to the the lower arm was too long. If I flipped the rod with the long and short tabs so that the short tab was connected to the clutch peddle and the long tab to the clutch everything aligned up perfectly but extremely hard to push the clutch. Very little "engagement area" but clutch engagement feels solid and wont just fall out of gear. I guess you could say the clutch engaged and disengage in the top 10% of clutch peddle. Fip it around the way is should be according to the diagram and clutch peddle feels good but not sure that the clutch itself really engages correctly. Alignment of the lower rod from the clutch fork to short tab is wonky and while in 1st or 3rd while in gear but not under load from engine "coasting in gear" it will fall out of gear just under the weight of the shift lever. I was thinking about just switching to a hydraulic clutch but knowing someone else has the same problem makes me think that something else is wrong with the linkage.
Forgot to mention that I also had to shorten the adjustable link to the clutch fork by about 5/8".
With the 2 ends screwed all the way in it was still too long to allow the fork any free-play. There is a mile of adjustment in the link so no issue to take some off.
Replacing the whole assembly with a hydraulic clutch would have been a better idea but is it is done now.
Thanks again to all for the help.
Cleg
Old 01-07-2020, 07:45 PM   #29
bender3 is offline
bender3
[QUOTE=mitchelllogic;277266]Used the existing pedal assembly. Used the washer to see where the hole would line up. Held it up to the pedal stop arm and centered it on the width of the clutch pedal arm. Turns out it located exactly where it needed to be.
Thanks for all the pics. They are really gonna help.
Old 01-07-2020, 10:08 PM   #30
mitchelllogic
No worries.
cj7 , clutch , confusion , linkage
79 CJ5 Clutch Linkage Wrangled13 Misc CJ Discussion 5 04-03-2017 11:25 AM
Clutch linkage tireman74 Drivetrain 5 07-09-2014 10:15 PM
Clutch linkage kit 74 cj5.... jasonmark1993 Drivetrain 11 09-24-2011 01:38 AM
70 cj5 clutch linkage 1970cj5 Drivetrain 2 05-27-2010 08:00 PM
