Default Clutch linkage
Old 02-25-2019, 05:28 PM   #1
weithman5 is offline
weithman5
Vehicle(s): 84 cj-7 renegade (original owner)
Rep Power: 4 weithman5 is on a distinguished road
Does anyone have a good picture of how the pivot ball fork and springs all go together inside the housing. Or good explanation. 84 cj 7 5 speed. I did not get good pictures before removing and the manual are a little iffy
Default Re: Clutch linkage
Old 02-25-2019, 06:14 PM   #2
Manic Mechanic is offline
Manic Mechanic
Manic Mechanic's Avatar
Images: 11
ill do my best as i dont have a pic.
the ball sits on top of the pedestal usually a lil grease will help hold it in place while u get the fork on.
the fork clips into the back of the throw out bearing then pivots on the ball. this is all inside the bell housing.
outside the bell housing its pretty straight forward your clutch pedal is attached to the "Z" bar (the bar connected to the side of the block and top of the frame) this i can get a pic of.
from the "Z" bar is another rod that sits in the little indentation on the shift fork.
finally the spring connects to a little hole about in the middle of the fork and attaches to the bell housing for return action.
i will post pics in a few minutes
Sry for the crappy pic's
Old 02-25-2019, 06:41 PM   #3
weithman5
Thx that helps. I assume the ball just sits in the casting inside the housing
On this post and that the little spring also goes from this post to the fork
Old 02-25-2019, 06:48 PM   #4
Manic Mechanic
Images: 11
Sounds right
Old 03-02-2019, 04:18 PM   #5
weithman5
Do I have this correct?
clutch , linkage
79 CJ5 Clutch Linkage Wrangled13 Misc CJ Discussion 5 04-03-2017 11:25 AM
Clutch linkage tireman74 Drivetrain 5 07-09-2014 10:15 PM
Clutch linkage kit 74 cj5.... jasonmark1993 Drivetrain 11 09-24-2011 01:38 AM
70 cj5 clutch linkage 1970cj5 Drivetrain 2 05-27-2010 08:00 PM
