Default Clutch adjustment question
Old 09-08-2010, 10:10 PM   #1
ftwflh is offline
ftwflh
Vehicle(s): 1976 CJ 5, 232 6cyl 3spd lots of rust,good frame,Dana 44s w/373 gears,ProComp 4in lift kit
ftwflh's Avatar
Rep Power: 10 ftwflh is on a distinguished road
My clutch doesnt engage until a couple inches from the top.
How do I get it to engage sooner?Shorten or lengthen the rod?
Default Re: Clutch adjustment question
Old 09-09-2010, 12:58 AM   #2
Saddle Tramp is offline
Saddle Tramp
Rep Power: 10 Saddle Tramp is on a distinguished road
On what vehicle?
Old 09-09-2010, 06:57 AM   #3
ftwflh is offline
ftwflh
ftwflh's Avatar
1976 CJ5 with 3spd
Old 09-09-2010, 09:58 AM   #4
shorten the adjustable rod at the clutch arm. between the bell crank and the clutch arm.
loosen the lock nut and shorten it , then tighten the lock nut again.
Old 12-19-2010, 05:12 PM   #5
ftwflh is offline
ftwflh
ftwflh's Avatar
Put in a new clutch and it engages too soon.Has about 1 1/2 -2 in free play
Which way do I need to take the adjuster longer or shorter?
Old 12-19-2010, 05:26 PM   #6
You need 3/4 to 1 inch of free play on the '76 and '77 CJs (later years need 1 to 1.25 inches)
You need to extend the adjustable link
Originally Posted by BusaDave9 View Post
You should have just over an inch of free play to the pedal.
First check over your clutch linkages to make sure something isn't out of place. The clutch fork (part 3) pivots on a ball. To adjust the clutch pedal travel you need to screw part 4 and 2 OUT make that assembly LONGER.
Check out this link
http://www.jeep-cj.com/forums/f2/cor...522/#post58425
Old 12-19-2010, 05:39 PM   #7
Let's make sure we are on the same page here.
Your CJ needs 3/4 to 1 inch of free play. By that I mean you should push the pedal 3/4 to 1 inch before the clutch moves. If you have 1 1/2 to 2 inches of free play that is too much. You need to make the clutch linkage LONGER.
Old 12-19-2010, 06:43 PM   #8
ftwflh is offline
ftwflh
ftwflh's Avatar
Got it lined out.Lengthened the rod set the play little over an inch and does great.Engages almost half way and doesnt grind going into any gear.
THANKS
adjustment , clutch , question
Clutch adjustment STEVE1103 Drivetrain 1 05-05-2013 03:57 PM
clutch adjustment or stuck plate??? need help 79cj7bogger Drivetrain 3 09-16-2012 06:07 PM
Lift affect clutch adjustment? thistle3585 Drivetrain 2 09-07-2012 01:37 PM
New clutch keeps needing adjustment...?? TrebleHook Drivetrain 15 05-01-2011 07:49 PM
clutch adjustment 79cj5 Drivetrain 2 10-17-2009 04:17 PM
