Default CJ7 Dana 30 with drums spindle bearing kit
Old 09-21-2017, 04:23 PM   #1
moriartii is offline
moriartii
Vehicle(s): '76 CJ7, AMC 360, TH400, Quadratrac, D30, AMC 20, Edlebrock intake, Holly 4bbl carb, 33inch tires
Rep Power: 0 moriartii is on a distinguished road
Does anyone know the proper spindle bearing kit for a 76 CJ7 with a Dana 30 and drum brakes?
So far I have picked up Napa BK1 and I have picked up Dana Spicer 706527x.
The Dana Spicer part was check via Rock Auto and via Danaaftermarket. The issue I am having is the spindle bearings appear to fit but the thrust washer, slinger and k seal are a tad too big.
Upon disassembly I notices the k seals were missing and the long axle shaft is all corroded.
Lee
Default Re: CJ7 Dana 30 with drums spindle bearing kit
Old 09-21-2017, 04:56 PM   #2
looking up the N.A.P.A. website, there seems to be other p/ns for that application, like bk1, bk2, bk3, bk4, and bk6. There was a difference in the spindles when disk brakes were added as the disk brake version was stronger and I have heard of the drum brake version breaking. I would suggest taking the spindle back to N.A.P.A. if you could.
Old 09-21-2017, 05:08 PM   #3
moriartii
Torx-
I dont have a spindle from Napa, the spindles are my originals, I am trying to track down the correct spindle bearing kit that has the outer axle slinger and K seal that fits correctly; so far they have been a bit too big.
Lee
Old 09-21-2017, 06:38 PM   #4
Let me clarify what I am trying to say. When I looked at the N.A.P.A. website, there was 5 spindle kits listed for your CJ, at least that's what I saw. You could have got a kit for the disk brake spindle which AMC converted to at the end of '76, or at least from what I have read. You might just want to take your spindle in to find a kit that will fit.
Old 09-21-2017, 07:08 PM   #5
moriartii
Yeah I see what you are saying now, not sure why I did not pick up on it before.
So I think you are correct in that the kits I am getting are for disk which would make sense since the spindles are larger and I assume the axle stub is too.
After finding the Dana 44 67_78 it appears I actually need a seal that looks like a wheel bearing one versus the K seal. The nice part is the kit I got from Denny's Driveshaft has the bearing and the v seal I need. Just need to source the oil seal.
Lee
bearing , cj7 , dana , drums , kit , spindle
Spindle Bearing Removal (Inside Spindle).. Greggsr219 Suspension and Steering 6 10-11-2015 06:09 PM
Prevailing torque nuts (spindle/wheel bearing) Techlight Drivetrain 9 06-18-2015 06:14 PM
Spindle bearing question Al Lindner Suspension and Steering 6 01-13-2015 05:25 PM
dana 30 pinion bearing bobt Drivetrain 3 01-18-2012 06:38 PM
