Default cj5 flywheel ring gear replacement
Old 06-30-2011, 10:24 PM   #1
rekocisko is offline
rekocisko
Vehicle(s): 1996 turbodiesel 2 door Tahoe, 1975 CJ5 with 4.2l in-line 6, and 1972 CJ5 with 304
Rep Power: 0 rekocisko is on a distinguished road
This may be a dumb question, but here goes. I know how to change out the ring gear on my flywheel, and how to disconnect the engine from the bellhousing, and so on and so forth. What I am unsure of, is what would be the easiest way to separate the engine from the bellhousing(and transmission) while the drivetrain is still installed in my 4.2l cj5? Do I need to leave the engine in place, unbolt the driveshafts, and drop the transmission, or do I need to use my hoist and pull the engine? I figure I can do it either way, just curious as to anyone's thoughts on the easiest way to do so. I am missing some teeth on the ring gear of the flywheel, and it needs to be replaced(the ring gear). Any thoughts?
Thanks in advance, Robby.
Default Re: cj5 flywheel ring gear replacement
Old 07-01-2011, 06:51 AM   #2
Purple77CJ7 is offline
Purple77CJ7
Vehicle(s): 1977 CJ 7; Amc 401 .30 over, Howell TBI, modified Dana 20 with Terra Low gears and twin sticks, NV 4500 5-speed, modified Dana 30 and Amc 20 both with 4.56 gears (narrow track), ARB air lockers front and rear, SSBC rear disc brake conversion, MICO Brake park brake, Navaho brake booster/ master cylinder, PowerTank CO2 tank.
Purple77CJ7's Avatar
Images: 37
Rep Power: 10 Purple77CJ7 is on a distinguished road
Robby, unless you need to pull the engine for other work, I think just drop the tranny and unbolt the bell housing would be easier. That's the way I have done it to replace the flywheel.
Old 07-01-2011, 06:53 AM   #3
Images: 221
I always just take the grill (and some times the fenders) off and pull the engine. Pulling the grill on a CJ is very easy and quick.
Old 07-01-2011, 07:56 AM   #4
rekocisko
Thanks for both of your replies, it sounds like either way would work just as well as the other. I just need to start working on it and knock it out. Thanks, Robby.
Old 07-01-2011, 07:59 AM   #5
rekocisko
I already replaced the cam, and have been needing to replace the rear main seal anyway, but my engine stand is currently occupied by my 304. So, I don't have any other place to put it.
Old 07-01-2011, 11:48 PM   #6
priceg is offline
priceg
Vehicle(s): 1982 CJ 7 4.2liter T176,D300,D30,AMC20 3inch lift, ARB lockers front and rear, 4.10gears, 33inch tires.
priceg's Avatar
Rep Power: 11 priceg is on a distinguished road
This method is a back saver for us old farts
cj5 , flywheel , gear , replacement , ring
Flywheel replacement on I6 258 SaltyNole Drivetrain 1 05-04-2013 09:49 PM
markings on a ring gear rr41mag Drivetrain 4 02-05-2013 08:40 PM
D30 ring gear torque specs Cheepjeep85 Drivetrain 2 11-23-2012 06:39 PM
Starter Ring gear dslywalker Drivetrain 14 05-04-2012 04:47 PM
Ring and pinion Germy Drivetrain 14 10-22-2011 08:43 AM
