Default Another Running Hot Post
Old 06-03-2019, 09:42 PM   #1
nhudson is offline
nhudson
Vehicle(s): 79 CJ7
Rep Power: 0 nhudson is on a distinguished road
Greetings, new member here. Just picked up a '79 CJ-7 with a 304 and am loving it so far. The only real issue I have at the moment is that I can't keep it cool. If I could constantly keep the speed up above 45 MPH I would be set I think. Stopping at lights or for trains and the temp gauge jumps up pretty quickly.
Right after I got it, I had the water pump and radiator replaced with both new parts. The guy I bought it from said he had replaced the thermostat already a few months ago. While I didn't verify this by physically inspecting it, the gasket looks brand new. Also when I got it the clutch fan was missing it's shroud. So my 1st thought after replacing the radiator was to install an electric fan.
I removed the clutch fan and set the new electric fan up as a puller on the inside of the radiator. I can verify that it moves some air, but the Jeep still runs hot at idle or slow speeds.
I am going to take it to a radiator place this week and just have them inspect everything to make sure it's actually flowing good, but other than that I am not real sure what to do. I'm almost to the point to drop $1000 on the Aluminium radiator and electric fan setup from Novak, but that's a hard pill to swallow especially after I just paid to have a new one installed.
A few things I plan on doing next. Let it come up to temperature with the radiator cap off and then take an actual temperature of the fluid. I don't have a IR temp reader, but I have a really good probe thermometer I can use, its upper limit is 600F.
Just looking for any thoughts or ideas I could try. Thanks for any help!
Default Re: Another Running Hot Post
Old 06-04-2019, 08:55 AM   #2
hole is offline
hole
hole's Avatar
Images: 28
With few exceptions, I take PO's word and work with a grain of salt. That said, I'd pull and verify the thermostat is in correctly and right temp range, and while I was there just replace it. Cheap insurance.
The Following User Says Thank You to hole For This Useful Post:
Lumpy Grits (08-01-2019)
Old 06-04-2019, 09:06 AM   #3
coldair is offline
coldair
coldair's Avatar
Images: 44
Please dont pull the radiator cap off when your jeep is at operating temp. You will get burned.
Old 06-04-2019, 09:31 AM   #4
another thing to do while you are trouble shooting this is to use the radiator flush stuff in your n=motor to clean up the rust deposits in the block. i would think a stock 304 would not have that much trouble keeping cool
Old 06-04-2019, 10:06 AM   #5
I hope you are not depending on just the OEM temp gauge here.
Many things can cause a false temp readings.
One of the biggest factors to cause a false high temp reading of the OEM gauge is the dash panel's ground(GND)connection. Many of us run a dedicated wire from the panel to the battery NEG(-)post
The other, is mis-matched sender and gauge.
Unless the seller handed you a receipt for this 'new' radiator etc. Don't believe him.
Are you running a fan shroud? You really should.
Also-A lean fuel mixture will cause higher engine temps.
Old 06-05-2019, 09:21 AM   #6
nhudson is offline
nhudson
Vehicle(s): 79 CJ7
Thanks for the replies. I went and bought a mechanical temp gauge and new 195F thermostat. I'll get them both installed after I get back from vacation. I think I'm just putting too much trust in the 40 year old stock gauge, the new radiator and electric fan definitely helps cool things down. I'll know for sure exactly what the temp is once I get the new gauge installed. I'll report back. Thanks again.
Sent from my Pixel 3 XL using Tapatalk
Old 08-01-2019, 01:15 PM   #7
JacksonLakeJeep is offline
JacksonLakeJeep
Vehicle(s): '85 CJ7, 258 I6
JacksonLakeJeep's Avatar
Rep Power: 0 JacksonLakeJeep is on a distinguished road
What's the verdict?
Old 08-01-2019, 02:05 PM   #8
nhudson is offline
nhudson
Vehicle(s): 79 CJ7
Funny you ask today, I finally did the following work over this past weekend.
1: new aluminum radiator with dual electric fans
2: 180f thermostat
3: FlowKooler Water Pump
4: New upper and lower radiator hose and heater hoses.
Still runs hot if I am not moving. I'm not really sure what else I can do at this point. I've taken it to a radiator shop and they told me what I put on should be sufficient to cool the jeep. I will say it cools much better while it's driving, but if I ever come to a stop or idle for too long it will overheat.
Nick
Old 08-01-2019, 04:19 PM   #9
2: 180f thermostat
Nick
How lean is running? Ignition timing?
Old 08-01-2019, 05:59 PM   #10
Could be lean fuel issue.
Need to check for vacuum leads.
Confirm your ign timing is correct.
Did you install the mech temp gauge and sender?
hot , post , running
And she's running! Lilredwagon Drivetrain 4 09-21-2016 08:26 PM
running amc 401 BrockGrimes Great Deals! 0 06-15-2014 01:25 AM
running hot tn trooper Drivetrain 9 12-20-2010 04:22 PM
newbie, first post. amc 360 not running right biohazard cj Drivetrain 19 12-15-2009 08:01 AM
CJ running hot! liljeeplover Drivetrain 22 09-29-2009 08:19 PM
