Question Another carb question!!!
Old 02-13-2020, 03:31 PM   #1
Gohawks is offline
Gohawks
Vehicle(s): '82 CJ7; gm151, not sure on the rest yet
Rep Power: 0 Gohawks is on a distinguished road
First I would like to thank the group for your wealth of info and your willingness to share it, this forum is great. I am getting ready to do a Rochester to Weber carb swap and I am wondering what to do with all the vacuum lines that wont be used in the new configuration. I'm not sure witch ones can be plugged off and what may need to go somewhere else. Any ideas on articles of pics/ diagrams that might help? Thank you. (1982 gm151ci. w/4spd.)
Default Re: Another carb question!!!
Old 02-13-2020, 08:11 PM   #2
JeeperChris is offline
JeeperChris
JeeperChris's Avatar
If a vacuum line is in use now, a carb swap will not change that, it will still need to be used.
The Following User Says Thank You to JeeperChris For This Useful Post:
Gohawks (02-13-2020)
Old 02-13-2020, 08:47 PM   #3
TnCJ is offline
TnCJ
TnCJ's Avatar
Rep Power: 2 TnCJ is on a distinguished road
You will need at least two vacuum lines. One for the vacuum advance on the distributor and one going to the PCV valve on the valve cover.
The rest depends on whether you have smog inspections or not.
If you have no inspections the rest can be plugged.
Smile Re: Another carb question!!!
Old 02-13-2020, 09:50 PM   #4
Gohawks is offline
Gohawks
I do not have emissions testing here so I should be ok there. I am mostly concerned with the line that goes back to the (I'm assuming) charcoal canister under the rear drivers side fender. It sounds like I can just plug that off. From
what I understand this carb swap not only improves some performance but will make timing and air/ fuel adjustments easier. I do plan on an MSD box as well. Thanks.
Old 02-13-2020, 10:17 PM   #5
Belizean is offline
Belizean
Belizean's Avatar
I run a Webber and MSD box and is a great improvement
Living the dream here on earth, but it's turning into nightmare on Uranus
Thumbs up Re: Another carb question!!!
Old 02-14-2020, 12:12 AM   #6
Gohawks is offline
Gohawks
That is GREAT to hear, I am hoping for the same results. Thanks
carb , question
carb question joshsmith1120 Drivetrain 5 08-31-2019 07:34 PM
Carb question mcraig8860 Drivetrain 1 12-14-2012 12:14 AM
85 CJ7 carb question (2.5l) clarythedrill Drivetrain 2 10-12-2011 08:03 PM
carb question usmcreeder Chassis and Body 2 06-15-2010 01:02 PM
carb question asphaltaddict Drivetrain 4 03-08-2010 06:01 PM
