Default 79 cj5 258 valve cover
Old 03-13-2020, 11:07 PM   #1
hattrck24 is offline
hattrck24
Vehicle(s): none
Rep Power: 0 hattrck24 is on a distinguished road
Just purchased a 1979 CJ five with the 258 engine and a four-speed transmission. It is leaking oil very bad, so I am hoping to replace the valve cover with a new one as well as gaskets. Searching the Internet and I cannot find any valve covers for a 258 that are not for the year 81 or after.
Is there a difference between the 258 engine from a 79 to an 81? Or would the same valve cover work?
Mine currently has a plastic one and whoever put it on last time couldnt get it to seat properly so they just used a ton of goop to try and fill the gaps and it is leaking oil.
Anyone know of a lead for a valve cover for a 79 258 that is metal?
Any help would be appreciated
Zac
Default Re: 79 cj5 258 valve cover
Old 03-14-2020, 10:38 AM   #2
hole is offline
hole
hole's Avatar
Images: 28
Can not help with the metal cover, but whatever route you go, FelPro Blue gaskets work quite well
Old 03-14-2020, 05:47 PM   #3
Flundertaker is offline
Flundertaker
Vehicle(s): '86 CJ7, 258, T5, D300, D30/D44 Pretty Much Stock . .
Rep Power: 0 Flundertaker is on a distinguished road
Make sure the leak is from the valve cover. Mine leaked like the Valdez and I assumed it was the valve cover. Well it turned out it was a little from the valve cover but most of it was coming from the fuel pump gasket.
Old 03-18-2020, 09:41 AM   #4
JimsCJ5 is offline
JimsCJ5
Vehicle(s): 1979 CJ5 Renegade 258, t-18 pretty much stock except for a later model aluminum intake manifold and Gronk 2150.
Rep Power: 7 JimsCJ5 is on a distinguished road
Those plastic covers are crap. We have an aftermarket alloy one on ours that eliminated the leaks. Pricey but worth it. I think I found ours on eBay.
Our Build thread: http://www.jeep-cj.com/forums/f98/fa...project-23905/
Old 03-18-2020, 11:24 PM   #5
Project86 is offline
Project86
Vehicle(s): 1986 CJ 7 Blue 2004 Chevy LWB CC, 2012 Corvette Grand Sport 1986 CJ 7 Red Garnet 1978 CJ 7 Kinda Orangish
Rep Power: 10 Project86 is on a distinguished road
I know they make 'em in aluminum, but can't remember where I've seen.
Old 03-19-2020, 09:08 AM   #6
mdeluca is offline
mdeluca
mdeluca's Avatar
Rep Power: 4 mdeluca is on a distinguished road
Seems that 81-86 are different than 72-80 in my searches.
Did find these:
https://www.ebay.com/b/Engine-Valve-...27/bn_93306965
MY BUILD THREAD --- 1986jeeprestoration.blogspot.com
Old 03-20-2020, 02:41 PM   #7
Make sure you have the correct PCV valve.
Be sure it's clean and working.
Gary
Old 03-22-2020, 09:07 AM   #8
Mrpeter63 is offline
Mrpeter63
Vehicle(s): 1983 CJ7, 4.2, T999, D300, AMC20, D30
Rep Power: 0 Mrpeter63 is on a distinguished road
The only difference between a plastic valve cover and a metal/aluminium cover is the plastic ones only have 3 or 4 bolts around the perimeter and use plastic plugs on the cover that go in the other holes to keep it from spreading out. Over time the heat and such make it warp. Anyways, your only option would be to go with a new plastic cover or get a metal cover and tap the holes(the holes are there so no drilling), just no threads. If you go the metal route, you will need a bottoming tap, start with a regular tap til it bottoms out them switch to the bottoming tap to thread the rest. The holes are shallow, 1/2"-3/4" maybe. It's easy to do just take your time, don't force the tap, and careful not to get metal shavings inside motor. I want to say threads are 3/8-16 but i might be wrong...
PS: Morris 4x4, Summit Racing, Quadratrac, Amazon, all sell plastic and metal/aluminium covers.
258 , cj5 , cover , valve
Valve Cover? 45frank Drivetrain 10 07-05-2017 05:32 PM
Valve spring and valve cover hitting glenn56 Drivetrain 1 04-17-2016 06:15 PM
Valve cover Plenty Coups Drivetrain 7 01-28-2013 07:16 AM
Valve cover where to buy al2ride Drivetrain 7 08-17-2011 08:28 AM
Getting valve cover off Kevinp Drivetrain 8 02-22-2010 12:09 PM
