Default 4.0 budget rebuild
Old 03-26-2019, 12:27 PM   #1
McSyd is offline
McSyd
Vehicle(s): Ď85 CJ7. Mainly stock. Getting a full restoration.
Rep Power: 0 McSyd is on a distinguished road
Hi all, new poster, long time reader.
Iím in the midst of a full blown cj7 restoration. I was planning to build a stroker for this Jeep but both 4.2 cranks I had were no good. So for now, to keep my project moving, I decided on a bare bones 4.0 rebuild. All stock. No mods at all.
Ended up needing 30 over bore and a valve job. Block and head were cut a total of 0.007Ē I believe he said (mighta been 11). Otherwise everything is pretty basic. This is my first proper engine job. So I need a little help from those who have rebuilt a 4.0 or 4.2.
My plans are to keep this as basic as possible. I ordered a 2150 carb and HEI dizzy from eBay. Planning to run the 4.2 intake on the 4.0 for simplicity. Iím going to save the original 4.0 intake in case I want fuel injection down the road. But in all likelihood Iíll end up doing a Chevy 350 down the road.
So a few questions:
Can I or should I reuse the original head bolts. I donít believe theyíre stretch bolts due to the torque specs. Iíve heard different opinions on reusing the old ones vs new. The machinist didnít recommend arp bolts for this build due to the torque requirements
Is there a way to reuse the oil pickup for the oil pump? Or should I just get a new one? Any tricks to getting the tube installed without the fancy tool?
Any major negatives with using the 4.2 intake? Iím thinking for simplicity, to just use it instead of the 4.0 intake since Iím going carbed. I might do fuel injection down the rd but weíll see. So I did t want to mess with plugging the injection ports on the 4.0 manifold and boogering it up in case I need it later.
Figured Iíd get an HEI dizzy. Will I still need to stock 4.2 ignition control module? Or can I just skip that all together?
Will I need the stock ecm for anything? Plans are to make this as basic as basic can be. Carburetor, distributor, electric fuel pump. I canít think of any reasons Iíd need the ecm or ignition module with this setup. But I could be wrong. If I do t need the computer for anything I wonít have to do a nutter bypass correct?
What do I need for a water pump? I read somewhere about needing a reverse rotation pump for the 4.0 in a cj7. If so, which way is ďreverseĒ? Clockwise or counter clockwise as youíre looking at the front from the radiator?
This motor was from an xj. Believe itís a 1992 block. It originally had air conditioning. Iím not gonna need that. Can I simply omit that and get a stock serpentine belt for a 4.0 without ac? What about a belt tensioner? Not sure my motor had one when I got it.
One thing thatís bugging me. I have the short block assembled. I installed the timing set and on the crank there is an oil slinger. It has a key way in it but pushes past the key and just sort of floats there. That canít be correct can it? Does anyone have a photo of how they sit on the crankshaft inside the timing cover?
Iíve included a few photos. I have 2 small core plugs leftover. Theyíre about 1Ē in diameter. Canít find anywhere on the 4.0 for these but I see on the 4.2 block thereís holes that size. Are these just extras in the kit for a 4.2 rebuild or is there in fact a location for these on the 4.2?
57e27af6-1495-44a7-a16c-727b28888cfd.jpg   e6b75f53-c9d1-4d2c-a425-78dc611be5ce.jpg   e6320c4c-c1ab-495b-a54e-bb919bd3264c.jpg
Default Re: 4.0 budget rebuild
Old 03-26-2019, 07:37 PM   #2
caveman is offline
caveman
caveman's Avatar
I'll try to answer some of your questions. I have reused head bolts but wouldn't advise it on a new rebuild. They have been stretched and likely to fail in the near future. Buy a new oil pickup. It would be a real pain to have to find out it should have been done. You can reuse the 4.2 intake. If your head is the high port head it will take some finageling to get to fit right, but it has been done before. Many times. You can omit both the controll module and the ecm. All the ecm ever did was adjust the old carter carburetor and it did it poorly in my opinion. Water pump. I can't remember which way it turns. You can get a belt for the engine without the ac pump but you will need the ac pump delete pulley I believe. I've never seen one without.
Sent from my LG-LS777 using Tapatalk
Old 03-26-2019, 08:02 PM   #3
RiverandSand is offline
RiverandSand
RiverandSand's Avatar
I will add if the engine ran a serpentine belt setup the water pump ran in reverse, if it was a v-belt system it ran in the other direction. So you will need the correct water pump to match belt system.
Old 03-26-2019, 08:18 PM   #4
All 4.0 ran the serpentine belt.
Old 03-26-2019, 09:43 PM   #5
McSyd is offline
McSyd
Thanks. I ended up getting a new oil pickup tube. Iím planning to use the CJ pan so I ordered a CJ tube. Iíll verify itís the correct length when it comes.
Iíll order new head bolts
I ordered a reverse rotation water pump for a YJ. I think (hope) I read thatís what I need. If not Iíll return it for another one. Itís a 4.0 block with a serp belt.
Iíve seen I may have some issues with bracketry but somebody said in a forum somewhere that a ZJ setup works perfectly on a cj7 swap. Iíll dig into that more later on.
Old 03-26-2019, 10:32 PM   #6
coldair is offline
coldair
coldair's Avatar
Images: 44
I used all brackets off my California 4.2 ( serpentine setup ) the water pump also worked. I did have to cut the stock 4.0 intake. For the 4.2 intake you wonít have to cut it. I did have to move the 4.2 intake up to match the ports of the 4.0 head. If you have any more questions Iím more then happy to help out where I can.
Old 03-27-2019, 06:46 PM   #7
So does the YJ setup.
Old 04-02-2019, 04:23 PM   #8
McSyd is offline
McSyd
Got a little done today. Got the cam greased up and the oil pump and pickup installed. Got the oil pan on, lifters in then got the head and rockers on. Had to clean up the pushrods a bit before they went I .
Wasnít sure where the 2 shorter head studs went. I had one in the front and one in the back corners. The front one interfered with the oil pan. So I moved it toward the middle. Hopefully it doesnít matter because I donít want to open it up again.
Had the same issue with bolts vs studs in the oil pan and valve cover. Not sure where the studs need to be. If anyone can advise Iíd appreciate it.
I ordered a YJ/TJ water pump which looks like itíll pump in the clockwise direction. So hopefully thatís correct.
Now itís in to giving out what goes where for the accessories. Thatís got me stressed for some reason. Having a bit of a time finding good assembly photos of the front of the 4.0. I also have 2 new ďwater pump studsĒ but not sure where those belong.
Hopefully this weekend I can get the engine installed in the frame and get the clutch in as well as the tcase and trans
87794bad-c184-4474-9223-706e234ce910.jpg   e53917be-393c-423d-8613-c9758deb6d80.jpg   155379b3-065f-4517-9ef3-34f7c7669249.jpg   f5feed19-0eb7-43e8-91e5-d385c41c957f.jpg   9c92fdc9-f055-4355-a42e-934cc067fe65.jpg
Old 04-02-2019, 07:43 PM   #9
Belizean is online now
Belizean
Belizean's Avatar
l like your 2x4 pretty well, but I have mine supported by a 2x8. A lot of weight hanging out there as you add more & more weight as the engine is built.
Old 04-04-2019, 02:19 PM   #10
McSyd is offline
McSyd
Got the engine on the chassis today then moved the tub out of the way. I broke a motor mount bolt off in the block which kinda sucked. But I managed to fix it. Itís coming along. Iím trying to find out what goes in the threaded hole of the water pump. I circled it in yellow in the photo. I originally thought the temp sensor for the computer went there but that goes into the t state housing, so thatís not it. Also, will I need that temp sensor for the computer for any reason? Iím planning to use a MC 2150 carb on the 4.2 intake and completely do away with the computer. So can I just plug that and omit that front temp sensor?
a9079663-f1db-41d8-897c-750fdc112561.jpg   134d3493-344d-4bb1-a8aa-a66a4c150a11.jpg   20dc2498-d498-4083-bb4f-13811250da14.jpg   f0c2085e-b7a7-4488-b849-2d9eae9af3b8.jpg
4.0 , budget , rebuild
Budget 1-Ton Axle JK Swaps Im Not Spam Jeep News and RSS feeds. 0 01-08-2018 05:00 PM
Budget Build andreww97 CJ Build Forum 19 08-29-2016 02:10 AM
budget 14B or budget 9in CJim7 Drivetrain 6 04-27-2016 11:01 AM
What do you do when you hit your monthly budget? Shane1977CJ5 Misc CJ Discussion 29 03-20-2015 05:09 AM
budget resto mod 71 cj5 bajahigh95 CJ Build Forum 0 12-16-2014 11:00 PM
