Default 350 chevy T4 clutch question
Old 08-26-2012, 08:31 PM   #1
cass is offline
cass
Vehicle(s): 1980 Cj5, 350 chevy (i built myself), T176, Dana 300, stock narrow trac 3.54 axles, locked in the rear, power steering, power brakes, tilt steering, Warn lockouts, 31x10.50x15 AT's, hi lift jack mounted on the front, bed lined tub, firestick cb setup, 5 in hella lights, NO RUST!!
Rep Power: 9 cass is on a distinguished road
so im in the middle of doing my sbc conversion. im mating it to a t4. i replaced to iron duke 2.5. today we made the motor mounts. im having trouble figuring out the clutch situation. i put on a 153 tooth flywheel. i have a clutch and pressure plate off of a camero my buddy gave me. the problem is when i measure everything out, the fingers that the throwout bearing push on are 1/4' longer than the 2.5 duke clutch. so if i bolt it together it will ride on the bearing all the time and probably have the clutch slightly disengaged. i cant find any info on pressure plate thickness or if some are "thinner". does anyone have any idea what model of car i need to order the clutch for to make it work?
Default Re: 350 chevy T4 clutch question
Old 08-27-2012, 07:08 AM   #2
Kane is offline
Kane
Vehicle(s): 1984 CJ-8 Restomod Scout axles 4 wheel disks, 258, ax15, D300.
Kane's Avatar
Images: 6
Rep Power: 12 Kane is on a distinguished road
That motor is going to churn your tranny into a pile of metal chips the first time to smash the go pedal.
Old 08-27-2012, 07:25 AM   #3
hole is offline
hole
hole's Avatar
Images: 28
Rep Power: 12 hole is on a distinguished road
Before you get any more time or money into your build, you might want to look for another trans. The T4 &5's are quite weak
Old 08-27-2012, 12:00 PM   #4
cass is offline
cass
i know they are weak. i researched this build for almost a year now. i have a sm465 and bellhousing waiting in my shed out back. i dont have the money to get the transfer case adapter. this will only be together for a couple monthes until the check book regroups and i get the adapter. then after the tranny it will be one piece axles. lol
Old 08-27-2012, 01:09 PM   #5
jasonmark1993 is offline
jasonmark1993
Vehicle(s): FJ cruiser (wifes ride) 2008 ZX10R, 73 CJ5, 408W, Toploader, Dana 20, 9" Dana 30 5.38 gears, next purchase=slicks
jasonmark1993's Avatar
Images: 10
Rep Power: 9 jasonmark1993 is on a distinguished road
Just have to adjust the linkage to get the freeplay you need. You may need to shorten both the lower rod (parallel to ground) and the upper rod (vertical to ground; runs up to pedal). Shoot for 1/4 to 3/8 between the throw out bearing and diaphragm.
When I did my Ford swap I think I had to shorten the solid portion that actually pushes on the clutch fork. Just cut some out if needed and weld back together.
I ended up with some serious pedal pressure with the mechanical linkage. Im sure part of this was due to the HP clutch Im running, but I think the main problem was the change in geometry. I messed around with it for a few weeks before installing a hydro clutch.
73 CJ 5, 408 Windsor, Toploader, 9"
Old 08-28-2012, 04:01 AM   #6
cass is offline
cass
i already have the hydrolic clutch setup. so the arm is all the way back. i ordered a clutch yesturday and it will be in today to see if it will work. its out of a chevy 2 with a 327. i can return it if its not right. they had the option for raised diaphram and short. so i ordered the short to see if its differnt than what i have. i will post the results and part numbers if it works.
Old 08-30-2012, 12:54 AM   #7
cass is offline
cass
LUK 04-002 is the clutch kit that works. its for the 153 tooth chevy flywheel (small diameter) im not sure what year of car but its a clutch out of a chevy 2 with a 327.
350 , chevy , clutch , question
clutch question northboundcj5 Drivetrain 10 11-04-2012 11:18 AM
CJ7 / Chevy Drivetrain Question GravyProv1 Drivetrain 5 10-31-2012 04:36 PM
jeep to chevy 350 conversion question wdcarut Drivetrain 0 03-15-2012 04:49 PM
1985 cj-7 chevy 350 swap question? bubbacummins Drivetrain 21 11-02-2011 08:07 PM
Clutch question Out of my mind CJ5 Drivetrain 10 08-23-2010 06:43 PM
