Default U-bolt flip
Old 02-11-2020, 01:37 PM   #1
Patrick is offline
Patrick
Patrick's Avatar
Greetings everyone. I would like to flip my U-bolts on the front D30 wide track non lifted CJ. The headache is the side with the bigger U-bolt going over the pumpkin cast end. My shocks are not mounted on the spring mount plates, so half the battle is done. Does anyone know a practical solution...
CJs are not getting older, they are getting faster!!!
Default Re: U-bolt flip
Old 02-17-2020, 11:58 AM   #2
Spduffee is offline
Spduffee
Vehicle(s): '78 CJ5 AMC 304, D20, T150, D30
Rep Power: 0 Spduffee is on a distinguished road
Never heard of that. What does reversing the u-bolts do?
Old 02-17-2020, 09:56 PM   #3
Patrick is offline
Patrick
Patrick's Avatar
Nothing. Just a little bit of undercarriage clearance. I like how they look, if done correctly.
Old 02-18-2020, 07:32 AM   #4
caveman is offline
caveman
caveman's Avatar
If you've ever sat on top of a stump with the U bolts dug into it, You would know why. It is for a little more and cleaner clearance.
Old 02-18-2020, 11:53 AM   #5
Patrick is offline
Patrick
Patrick's Avatar
Very true, Caveman. I just dont want to start a debate here. Just an answer to my post. Thank you.
Old 03-24-2020, 04:33 PM   #6
007 is offline
007
Vehicle(s): #1 - 1977 CJ-7 Renegade (Daisy Jane), Levis trim, 304 V8, TH400, QuadraTrac w/Low Range, D30, Trac-Lok AMC20, 3.54's, Factory Air, Tach, Clock, red with Levis blue seats and top(s), 31x10.50x15 Destination MT's, Edelbrock Performer intake, Holley Sniper EFI, MSD6, MSD ProBillet distributor, OME shocks, one-inch shackle lift, Reese tow bar, G2 one-piece axles. #2 - 1984 CJ-7 Laredo (The Texas Hooker Project), 401 V8, 700r4, Spicer 18, D44's, 5.38's, Eaton E-Lockers, Rocky-Road SOA, Poison Spyder outboard kit, YJ rear sprgs, Waggy front sprgs, tach, clock, red with gray seats and top(s), 35x12.50x15 Mickey Thompson Baja MTZ's, Edelbrock Performer intake, Holley Sniper EFI, MSD6, Sniper Hyperspark distributor, Rocky-Road shocks.
007's Avatar
Rep Power: 10 007 is on a distinguished road
Patrick - not talking you out of your original question...but...something else to consider - https://www.rocky-road.com/jeep-ubolt-skidplate.html
flip , u-bolt
2 Bolt or 6 Bolt steering knuckle? JeeperChris Suspension and Steering 9 12-22-2019 04:04 PM
Tie rod flip, why? tireman74 Suspension and Steering 14 06-03-2014 10:57 PM
Tie rod flip Sasquach Suspension and Steering 98 10-24-2012 01:16 PM
Tie Rod Flip dondi Suspension and Steering 20 06-29-2012 10:22 AM
Stock shackle length bolt to bolt? suburban99 Suspension and Steering 10 01-27-2012 04:39 PM
