Default Re: Suspension advice needed
Old 09-14-2017, 06:43 PM   #11
I would think so, if the frame is 'sound'.
Use at least GD5 hardware, and loctite. Torque to spec.
Old 09-14-2017, 06:59 PM   #12
tarry99 is offline
tarry99
Rep Power: 11 tarry99 is on a distinguished road
Originally Posted by Montanaphilly View Post
Right around the same idea I have , bolts are ok?
So are your rear shackles mounted to the same fixed factory rear spring hanger on the bottom of the frame?
The Following User Says Thank You to tarry99 For This Useful Post:
Lumpy Grits (09-14-2017)
Old 09-14-2017, 07:02 PM   #13
OP-Can you post some pictures for us to see the area in question?
Old 09-14-2017, 07:13 PM   #14
Montanaphilly is offline
Montanaphilly
Vehicle(s): None
Rep Power: 4 Montanaphilly is on a distinguished road
It's a 1975 postal jeep , 2.5 wide springs , soa, the hangers are on the sides of the frame , I would consider them more of spindles , as there's only a nut and washer holding the shackles on,
Old 09-14-2017, 07:18 PM   #15
tarry99 is offline
tarry99
As Lumpy stated above..........pictures would be great.
advice , needed , suspension
Suspension upgrade ideas needed etexjeep Suspension and Steering 42 05-10-2014 09:08 AM
Newbie looking for suspension advice gaddough Suspension and Steering 7 08-14-2013 04:50 PM
New shackles needed for 4" suspension lift?? dinolambchop Suspension and Steering 5 04-23-2013 04:44 PM
Introduction and Need Suspension Advice ColoradoCJ Suspension and Steering 13 11-28-2012 04:35 PM
Advice on Suspension/Lift Kit TrebleHook Suspension and Steering 10 04-19-2011 09:11 PM
