Default Suspension advice needed
Old 09-14-2017, 12:29 AM   #1
Montanaphilly is offline
Montanaphilly
Vehicle(s): None
Rep Power: 4 Montanaphilly is on a distinguished road
Whats up guys , i have an ol postal jeep ive been doing mods to and I'm just starting to make the suspension more dirt worthy ,I've put together custom leaves, but have the stock main leaf, i want to do a shackle relocation in the rear, along with a longer shackle , while trying to achieve desired shackle angle, my question is this....can I cut the rivets off of the shackle hanger .....relocate hangers.... drill four holes .....then use some good BOLTS instead?
Default Re: Suspension advice needed
Old 09-14-2017, 08:29 AM   #2
IMO-Shackle reversal, ain't worth the effort.
What do you think you gain from this?
Old 09-14-2017, 11:08 AM   #3
tarry99 is offline
tarry99
Rep Power: 11 tarry99 is on a distinguished road
Yes , the hanger needs to be moved to achieve the proper shackle angle now at the rear , and be careful about using longer shackles.......you'll also have to change your mounting up front to accommodate the need to get the springs back working on a horizontal plane......which also means that both castor and pinion angle up front need to be looked at...during the change.
All of this needs to be done at full bump............meaning , all the weight has to be in the vehicle to get the correct angle..........New springs maybe starting at 15-20 degrees and used 25-40 degrees.
Old 09-14-2017, 12:41 PM   #4
Montanaphilly
Vehicle(s): None
With the hanger moved forward and a longer shackle with proper angle , trying to achieve better down travel , and a slightly smoother ride
Old 09-14-2017, 12:42 PM   #5
Montanaphilly
Vehicle(s): None
Helpfull info Thank you
Old 09-14-2017, 01:38 PM   #6
Isn't the shackle at the rear of the Jeep now?
Smoother ride with leaf springs, is usually obtained with very 'soft' valved shocks.
Old 09-14-2017, 02:40 PM   #7
Montanaphilly
Vehicle(s): None
The shackle is at the rear , but is standing nearly vertical or close to it , giving the shackles no leverage on the springs, for example , while going over a speed bump , theres no cushion , it's just a really rough bounce, I know I can't achieve a smoothness like you would get out of coilovers , but this suspension is bouncy enough to really hate driving it in the dirt ... as for shocks ,I have some Napa sensitracks...... No remote resi but they work ok, really the only thing that seems to help with ride quality is tire pressure , but with a 3 speed auto , you can really feel drag with too low of pressure,
Old 09-14-2017, 03:27 PM   #8
tarry99 is offline
tarry99
Leaf springs in conjunction with shackles at one end are designed to complement each other as far as ride quality........shocks are designed to limit the speed of compression or extension of the sprung axle package.
All of which work together.......to stiff of spring , no shackle angle , or an aggressive shock will make for a bad ride.......
Folks also get caught up in Lift springs that are longer mechanically for lift , but still in most cases required to operate in the same OEM space......which equals a rough ride mostly due to shackle angle. A longer wider spring with lift is a better choice to manage both ride & lift.....but of course you have to move things around.
Old 09-14-2017, 03:47 PM   #9
You might want to think about moving the rear shackle hanger on the frame forward, and inch or two. Then look into having your springs re-arched.
Old 09-14-2017, 04:35 PM   #10
Montanaphilly
Vehicle(s): None
Right around the same idea I have , bolts are ok?
advice , needed , suspension
Suspension upgrade ideas needed etexjeep Suspension and Steering 42 05-10-2014 09:08 AM
Newbie looking for suspension advice gaddough Suspension and Steering 7 08-14-2013 04:50 PM
New shackles needed for 4" suspension lift?? dinolambchop Suspension and Steering 5 04-23-2013 04:44 PM
Introduction and Need Suspension Advice ColoradoCJ Suspension and Steering 13 11-28-2012 04:35 PM
Advice on Suspension/Lift Kit TrebleHook Suspension and Steering 10 04-19-2011 09:11 PM
