Default Steering stabilizer bracket.
Old 04-07-2020, 03:39 PM   #1
Vikingone is offline
Vikingone
Vehicle(s): 85' CJ7, 4.2 Liter, swapped in T18
Vikingone's Avatar
Rep Power: 3 Vikingone is on a distinguished road
So if taking apart the front end. Cleaning and painting parts. Do I need to mark where the steering stabilizer bracket goes?
Default Re: Steering stabilizer bracket.
Old 04-07-2020, 06:53 PM   #2
RiverandSand is offline
RiverandSand
RiverandSand's Avatar
Wow that's one beefy bracket. Couldn't hurt but, more important is to record the measurement of the tierod lenght if you plan on taking it all a part. So the alignment won't be to far off when you reassemble the steering rods. Adjusting the stabilizer isn't really hard if you don't.
The Following User Says Thank You to RiverandSand For This Useful Post:
Vikingone (04-08-2020)
Old 04-08-2020, 09:05 AM   #3
Vikingone
Vikingone's Avatar
I definitely be measuring the tie rod length. I normally also count the amount of threads exposed on the tie rod ends.
Old 04-08-2020, 10:35 AM   #4
Patrick is offline
Patrick
Patrick's Avatar
No need. Tie rod adjusts caster, drag link centers your steering wheel. Very easy to align. Do not pay an alignment shop 200 bucks. You will never get it right trying to match your measurements during reassembly. Consider replacing ball joints. If you do replace them, do not use the included rubber boots. Get some high quality aftermarket ones.
CJs are not getting older, they are getting faster!!!
The Following User Says Thank You to Patrick For This Useful Post:
Old 04-08-2020, 01:37 PM   #5
Vikingone
Vikingone's Avatar
Ill be definitely replacing the ball joints. Gonna go with MOOG
Old 04-08-2020, 01:49 PM   #6
Patrick is offline
Patrick
Patrick's Avatar
Let me correct myself. Tie rod adjusts toe in. Didnt mean to confuse anyone.
Old 04-09-2020, 08:51 PM   #7
RiverandSand
Note to self , don't use this guys alignment shop. The shop I used was 70 bucks, well worth the money spent.
I ball parked it after all my work and was still a few degrees off, nothing like a good laser alignment
Definitely get it aligned after all your work.
Vikingone (04-10-2020)
Old 04-09-2020, 09:32 PM   #8
Patrick is offline
Patrick
Patrick's Avatar
Did you ask them to give you an extra degree or two for your oversized tires or lift?
Old 04-11-2020, 02:19 PM   #9
RiverandSand
Yes, they got it into spec. The there is a 2 difference between the castor on right and left side, he thinks the axle maybe tweaked slightly. It was a wheeled pretty hard before I got, as everything was shot. It steers way better now then it ever did before, it is still a 5 so it's not luxury car steering.
Old 04-11-2020, 02:21 PM   #10
Patrick is offline
Patrick
Patrick's Avatar
I hear you.
bracket. , stabilizer , steering
Steering Stabilizer Bracket Loose? Spduffee Suspension and Steering 6 12-06-2019 04:21 PM
Steering Stabilizer Vick68 Suspension and Steering 4 02-11-2013 12:31 PM
cj7 steering stabilizer HELP!! Dan86CJ7 Suspension and Steering 5 05-05-2012 10:35 PM
1978 cj5 steering stabilizer kit RageOn Suspension and Steering 7 12-20-2011 07:10 PM
Steering Stabilizer 81laredo Suspension and Steering 12 02-28-2010 02:01 PM
