Default Re: Steering rebuild kit
Old 06-28-2018, 10:16 PM   #11
jp360cj is offline
jp360cj
Originally Posted by Jimmyp View Post
To make sure i am understanding correctly a 1980s jeep wagoneer steering pump and box with a manual shaft is an upgrade and for the most part direct swap. I have a chevy 305 right now and was wondering if the wagoneers pump is needed because i have one already on just not sure from what and if it is will it work?
The CJ box is a fixed ratio. The Wagoneer box is a variable ratio. I prefer the way it drives over the stock box, so I consider it an upgrade. The pump isn't needed, but you will need to check the fittings on the 305's pump. If it's an 80 or newer, it should have metric o-ring fittings and you'll need an 80 or newer box. If it's a 79 or older pump then it should have SAE flare fittings and you will need a 79 or older box.
Old 07-10-2018, 07:02 PM   #12
Jimmyp is offline
Jimmyp
Vehicle(s): 80 cj5, 305.
Rep Power: 0 Jimmyp is on a distinguished road
https://www.morris4x4center.com/borg...000000905.html
Will this work with the 80s waggy steering shaft
Old 07-10-2018, 10:00 PM   #13
jp360cj is offline
jp360cj
Yes, that manual CJ shaft will fit the Waggy power steering box.
The Following User Says Thank You to jp360cj For This Useful Post:
Jimmyp (10-17-2018)
kit , rebuild , steering
Jeep Cj5 steering column rebuild (tilt) brownrxmd Suspension and Steering 8 10-02-2019 09:49 AM
Steering column rebuild thread Idahododgeram Suspension and Steering 22 06-14-2018 06:30 PM
Steering: Better to upgrade or rebuild? BlackBetty Suspension and Steering 14 08-11-2012 05:12 PM
Shorten the steering column and smaller steering wheel. Workingdog Misc CJ Discussion 23 05-01-2012 07:34 PM
Steering box/rebuild or replace catman Suspension and Steering 13 08-18-2009 09:28 AM
