Default Re: Steering linkage pics
Old 10-14-2016, 04:38 PM   #11
Lumpy Grits is online now
If you do not have a title(AKA 'pink-slip')in your name. YOU, do not own this motor vehicle, in any legal sense. How can you expect to register a vehicle and insure it, if you are not the registered owner?
Bill of sale only proves you didn't steal it.........
I wish you only good luck here! But, you may have a battle on your hands with your state's dept of motor vehicles.
Respectfully,
Old 10-14-2016, 05:43 PM   #12
JCM 1420 is offline
JCM 1420
Vehicle(s): '84 CJ 7, 258, 4 speed
Rep Power: 0 JCM 1420 is on a distinguished road
Respectfully,
Common practice in GA on vehicles before '85. Already have it registered and insured.
FYI - the way it works is you can register a vehicle made before 85 if the previous registration in the state system is under the name of the person who you have a bill of sale from. If this isn't the case, then you submit a form, they run numbers to make sure the vehicle isn't stolen. All of this only applies in GA, I'm not sure of other states.
In my case it had a current registration to the guy I bought it from, so it wasn't a big deal at all, they even provide a boilerplate bill of sale from the DMV.
Is it ideal, probably not, but I was willing to roll with it on a cheap 3rd vehicle/project vehicle.
Appreciate the help guys, this forum is proving to be a wealth of information, looks like I'm going to be looking at a shackle swap, off to search the old threads I go.
The Following User Says Thank You to JCM 1420 For This Useful Post:
Lumpy Grits (10-14-2016)
Old 10-14-2016, 06:08 PM   #13
Glad to hear this.
Sounds like you live in a state that has reasonable requirements.
very few states would be that easy to work with.
Heck-I still have to SMOG test my '85, CJ-7 every 2 years here in PRK(CA.)
Old 10-24-2016, 01:30 PM   #14
JCM 1420 is offline
JCM 1420
Bumping this thread with an update...
Switched out my front shackles, didn't measure them but they were clearly longer than stock by a good bit. For now I've just got some cheap crown shackles up front as I wanted to see what other problems I might uncover.
Steering and handling is 10x's better than it was. It still has some issues but I feel a lot more comfortably tackling them one at a time now that the general geometry is close to what it should be.
Long term plan is to order a 2.5 inch lift kit with new leaf springs and shackles just to get all new hardware.
I would say the stock shackles are probably half as long as the shackles that were on the jeep, and the change in stance in barely noticeable.
Old 10-24-2016, 01:55 PM   #15
Thanks for the update, looking at those Crown spring shackles on the net, they seem to look pretty oem.
Old 10-29-2016, 03:01 PM   #16
DHugg is offline
DHugg
Vehicle(s): '80 CJ7 304AMC crate with 8KMiles: MC2100 - AMC20 rear w/Superiors - Dana30 front - TF999 - Dana300TC - 35x12.5's - Tilt steer column - Flaming Rvr EZ-Steer Shaft - AGR Super Pump - AGR Super Box II - RockyRidge HD Brace - New home-designed digital TEMP - GAS - OILPR - CALIBRATE gauges.
Images: 46
Rep Power: 11 DHugg is on a distinguished road
JCM 1420:
I just finished a rebuild of the entire frontend, 1980 CJ-7, for the same reasons you gave..... it wanted all the road when a pothole shakes up the front end. The tierod/draglink fip was the easiest. The knuckle in the front wheel axles was the next to worst, one locked up, the other really stiff. The WORST was getting the upper/lower ball joints out and new ones back in. My wife could hear me from the kitchen; said she learned a few new words.
Old 10-31-2016, 08:50 AM   #17
JCM 1420 is offline
JCM 1420
Originally Posted by DHugg View Post
JCM 1420:
Thanks for the tips. A complete front end rebuild is in the future, probably at the same time as I replace the springs. Just swapping the shackles really helped things so for now I'm content with the handling. Next up is fixing the very intermittent stall at idle (it's a pain to trouble shoot when it doesn't happen very often) and figuring out what part of my drive train is leaking like a sieve dripping oil all over the driveway. Oh yeah, and the funny noise related to the clutch/transmission. Hopefully I'll have it squared away by the Spring.
Thanks again to everyone on this site, I've found a ton of great information through searching old threads.
linkage , pics , steering
Curved Dana 44 Tie Rod, CJ7 Steering Linkage RotateSpeed Suspension and Steering 29 04-04-2016 12:26 PM
Custom length steering linkage Kane Suspension and Steering 5 01-13-2014 05:06 AM
Steering problem , linkage is off TOOLTIME1959 Suspension and Steering 3 09-13-2013 04:21 PM
Steering Linkage - Dana 44 Swap Scramble Suspension and Steering 10 03-05-2013 12:55 PM
Steering Linkage Upgrade TCs CJ7 Suspension and Steering 6 09-13-2010 02:54 PM
