Default steering box adjustment
Old 12-27-2012, 08:30 PM   #1
mikemrq is offline
mikemrq
Vehicle(s): 84 CJ7, 360 AUTO
Rep Power: 0 mikemrq is on a distinguished road
84, CJ7, Auto. I see some type of adjustment screw on top of my steering box. What exactly does that adjustment do?
Default Re: steering box adjustment
Old 12-27-2012, 09:48 PM   #2
Posi is offline
Posi
Posi's Avatar
That is the pitman shaft adjusting screw, it adjusts the drag on the pitman arm.
Old 12-29-2012, 12:21 AM   #3
tarry99 is offline
tarry99
Rep Power: 11 tarry99 is on a distinguished road
That screw is for the Sector shaft and how it preloads the recirculating bearings inside......a fine adjust only at best and will to little to help a worn out steering gear.
Old 12-29-2012, 10:03 AM   #4
Posi is offline
Posi
Posi's Avatar
There is only 2 adjustments for the box, pitman shaft (also called sector shaft) drag, and wormshaft bearing preload. The adjustment at the top of the box is the pitman shaft adjustment screw. Wormshaft preload is made with the adjuster plug.
adjustment , box , steering
Valve adjustment blaylock6502 Drivetrain 9 10-06-2019 11:25 AM
Clutch adjustment STEVE1103 Drivetrain 1 05-05-2013 03:57 PM
Power Steering adjustment Duhwhat Suspension and Steering 3 12-25-2011 01:06 PM
Air Filter Adjustment? phinleft Drivetrain 4 08-27-2010 09:12 PM
clutch adjustment 79cj5 Drivetrain 2 10-17-2009 04:17 PM
