Default Rugged Ridge Draglink and Tierod Kit
Old 03-05-2020, 03:02 PM   #1
toolow is offline
toolow
Vehicle(s): 1980 cj7 258 4 speed
Rep Power: 0 toolow is on a distinguished road
I got this kit today for my 80 cj7 and of course no instructions. I looked on the internet and my Hayes, poopieons manuals. I can't find the torque specs. Anyone know them ? Im pretty sure the orginals were not torqued right since after I removed the nail ( instead of cotter pin ) the castle nut just spun off by hand.
Sent from my SM-G920V using Tapatalk
Default Re: Rugged Ridge Draglink and Tierod Kit
Old 03-05-2020, 07:34 PM   #2
RiverandSand is offline
RiverandSand
RiverandSand's Avatar
I believe it's 60 ftlbs. If it is the same as mine with the 3/4 ton tierod ends.
The Following User Says Thank You to RiverandSand For This Useful Post:
toolow (03-05-2020)
Old 03-17-2020, 01:01 PM   #3
toolow is offline
toolow
Got it installed, went to go for a test drive but rear wheel cylinder leaked, so now it sits waiting for me to replace the rear brake system including lines.
Old 03-17-2020, 01:37 PM   #4
Patrick is offline
Patrick
Patrick's Avatar
In response to your question, I would go by the bolt/nut grade, size and thread pitch. If itís 1/2-24 grade 8, it can take up to 90 lb-ft. I would torque it 60 to 70, no more, as stated before.
Old 03-19-2020, 09:39 PM   #5
cglax6 is offline
cglax6
cglax6's Avatar
My 76 FSM says 50 lb-ft. I just installed a tie rod and drag link from Big Daddy Offroad. I set my torque wrench to 50, and had to tighten each castle but a little bit to get the cotter pin homes to line up right.
Sent via Google translate using braille through Tapatalk
The Following User Says Thank You to cglax6 For This Useful Post:
Patrick (03-19-2020)
draglink , kit , ridge , rugged , tierod
Rugged Ridge Carpet ? 440sixpack Chassis and Body 0 08-23-2019 05:36 PM
Rugged Ridge lift Agent915 Suspension and Steering 8 09-24-2016 04:08 PM
Rugged Ridge Steering box mount LocksNLockers Suspension and Steering 9 09-07-2016 06:04 PM
Big daddy vs. Rugged ridge Dan77CJ7 Suspension and Steering 23 05-26-2014 02:20 PM
Rugged Ridge HD Shackle How To/Instructions. Techlight Suspension and Steering 1 05-21-2014 08:41 PM
