Default power steering pump bracket with 4.0 head swap
Old 12-31-2018, 02:52 PM   #1
jmbridges is offline
jmbridges
Vehicle(s): 1981 cj7, amc 258, t176, Dana 30
jmbridges's Avatar
Rep Power: 0 jmbridges is on a distinguished road
Hi all, still in the middle of my 81 cj7 rebuild, currently reassembling the engine with a 4.0 head swap. Has gone relatively smoothly, with some assistance, but wanted to get some thoughts on the power steering pump bracket. I knew there was going to be some modification required - too short now and won't clear the 4.0 exhaust - but I have seen very little specific info on how to modify. I installed a banks exhaust header, rather than stock exhaust manifold, and i think the front tube juts out farther than usual. Pic attached (sorry is oriented weird, couldn't get it to rotate). Anyway, would be interested in hearing from those who have done the swap what they did, and seeing some pics if available. thanks in advance.
Default Re: power steering pump bracket with 4.0 head swap
Old 01-01-2019, 09:17 AM   #2
hole is online now
hole
hole's Avatar
Images: 28
Rep Power: 12 hole is on a distinguished road
I cut/notched mine as needed with a sawzall and cleaned it up with an angle grinder.
The Following User Says Thank You to hole For This Useful Post:
jmbridges (01-01-2019)
Old 01-01-2019, 09:08 PM   #3
yellow85cj is offline
yellow85cj
Vehicle(s): 85 CJ7, 258,4.0 head, T177, D300, Dana 30, AMC 20, 3.54
Images: 3
Rep Power: 11 yellow85cj is on a distinguished road
My bracket cleared the stock 4.0 manifold with room to spare, so can't help with that part.
To add height to the bracket, since the 4.0 head is taller, I bolted up the bracket and then bolted a 1/2" (IIRC) to the intake, marked them, cut some off of both where they overlapped, then welded the washer to the bracket. I did tack them together when i did the last test fit.
The lower intake bolt hole was moved and isn't a "complete" hole, but a washer with the bolt keeps it in place no problems.
The Following User Says Thank You to yellow85cj For This Useful Post:
4.0 , 4.0 head , bracket , head , power , power steering , pump , steering , swap
Power Steering Pump Bracket L83 5.3Ltr beasleyrb Drivetrain 4 10-31-2018 05:41 PM
Power Steering Pump bracket DIY Kit or Plans??? bgauweiler Suspension and Steering 2 02-25-2018 07:08 PM
Power Steering Pump Bracket for 304 whodathunkit Suspension and Steering 14 06-25-2017 10:49 PM
Power steering bracket and pump for 360 FiNorman Suspension and Steering 2 06-08-2014 09:38 PM
304 Power Steering Pump Bracket Broke derekcj5 Drivetrain 1 12-09-2011 04:22 PM
