Default Power Steering Pump Bracket for 304
Old 04-21-2014, 11:53 AM   #1
whodathunkit is offline
whodathunkit
Vehicle(s): 1986 CJ-7 258 I-6 5 spd, 2007 Chevy Silverado 1500 5.3L V-8 Z71 4x4
whodathunkit's Avatar
Rep Power: 0 whodathunkit is on a distinguished road
The project: I am about to take on a power steering conversion project for my '76 CJ-5 with a 304. I am pulling the parts off of an '80's CJ that had a 258 engine in it. Everything from beyond the firewall should be a bolt-on job, but...
The problem: can I reuse the power steering bracket from the 6 cylinder engine and bolt it onto the 8 cylinder engine, or is it a different bracket configuration? I'm looking for a bolt on solution, not going to weld anything.
Anyone know where I could buy the correct bracket if the one I have from the 258 will not work? I cannot seem to find it online.
Thanks for the help!!
Default Re: Power Steering Pump Bracket for 304
Old 04-21-2014, 04:00 PM   #2
yellow85cj is offline
yellow85cj
Vehicle(s): 85 CJ7, 258,4.0 head, T177, D300, Dana 30, AMC 20, 3.54
Images: 3
Rep Power: 11 yellow85cj is on a distinguished road
No the 4.2 pump bracket will not work on the 304. The pump should be fine.
The v8 bracket looks like this.
Have to hit the junk yard (304 or IIRC the 360 will also fit) or ebay.
Old 04-21-2014, 04:31 PM   #3
whodathunkit
Thanks for the heads up... Looks like this will be more of a challenge than I initially thought as it proves to be a tough one to find. Thanks.
Old 04-21-2014, 07:44 PM   #4
hdgapeach is offline
hdgapeach
Vehicle(s): Right now, only one '76 CJ5. 304 with a three speed stick. Everything else is pretty much stock 'cept for a 4" suspension lift. Came to me with a back breakin' 4" suspension lift attached to a reverse shackle setup (Reversed the reverse shackle crap and now she rides like a Caddy!) Also posess a few 60s & 70s Mustangs and a couple of late 70's F150s 4X4s.
Rep Power: 7 hdgapeach is on a distinguished road
I think you'll do better hittin' the bone yards and look for anything with a 304 or 360 in it.
I picked ebay apart a while ago and didn't come up with anything for ya.
Good luck! If you don't find something soon, add another post and I'll see what luck I have around west central GA.
Old 04-21-2014, 09:10 PM   #5
Rep Power: 14 mtnwhlr is on a distinguished road
Me to I have a Jeep bone yard by me I can drop by and see if they have anything.
Old 04-22-2014, 10:37 AM   #6
whodathunkit
Sweet, thanks guys I appreciate it! Let me know if you stumble on one.
I will keep looking. Thank you.
Old 04-24-2014, 06:36 PM   #7
DHugg is offline
DHugg
Vehicle(s): '80 CJ7 304AMC crate with 8KMiles: MC2100 - AMC20 rear w/Superiors - Dana30 front - TF999 - Dana300TC - 35x12.5's - Tilt steer column - Flaming Rvr EZ-Steer Shaft - AGR Super Pump - AGR Super Box II - RockyRidge HD Brace - New home-designed digital TEMP - GAS - OILPR - CALIBRATE gauges.
Images: 46
Rep Power: 11 DHugg is on a distinguished road
Here are some photos that show PS bracket parts.... might be of help in your hunt.
bonne chance,
Denny
power-steering-pump-bracket-one-half.jpg   pspump-bracket-backside.jpg   steering_pump-14dec09_-011.jpg   topside-steering-pump-22novl09-774x800-031.jpg
Default
Old 04-28-2014, 03:10 PM   #8
Deerejeep is offline
Deerejeep
Vehicle(s): '81 CJ7 4 cyl. S4, d300 soon to be amc360 t18 D300. Restoration. '08 JK 4" lift, 35" and on and on.
Rep Power: 7 Deerejeep is on a distinguished road
Here's a pic that was helpful for me.
Old 04-28-2014, 03:52 PM   #9
whodathunkit
Thanks!
I just picked up all of the components (except for the bracket).
If anyone has or finds an extra, let me know!
Old 06-13-2017, 11:47 AM   #10
EVERYUSERNAMEISTAKEN is offline
Vehicle(s): 84 CJ7, 4.2L, D300, D44's w/ E-lockers front and rear, 4.88's, 4" springs, on 36" TSL's
Rep Power: 4 EVERYUSERNAMEISTAKEN is on a distinguished road
Does anyone have access to a spare Belt tensioner bracket? I just broke mine and can't find anyone that sells it.
304 , bracket , power , pump , steering
225 V6 power steering bracket CJrider67 Suspension and Steering 7 03-08-2014 09:52 AM
304 Power Steering Pump Bracket Broke derekcj5 Drivetrain 1 12-09-2011 04:22 PM
Smog pump bracket during power steering and brake conversion chrisparks Suspension and Steering 3 10-13-2010 08:20 PM
Power Steering Box Bracket suggestions. RTRCJ7 Suspension and Steering 12 09-21-2010 03:44 PM
