Default New PS pump not bleeding?
Old 04-29-2018, 06:35 PM   #1
JohnKcj5 is offline
JohnKcj5
Vehicle(s): 82 CJ5, 304, 4 speed, AMC 20, WARN 8274, 3" lift, 33" ProComp M/T's
Images: 2
Rep Power: 3 JohnKcj5 is on a distinguished road
So I installed a new Borgeson PS pump. I put the front end in the air and did the left/right bleed procedure at least 100 times. There is NO power steering at low idle. It starts working around 1,500rpm, but it's sort of twitchy. Took it for a spin around the block and it's no better. Something isn't right. Before I send the pump back, does anyone have any tricks? Am I missing something?
I should note that the fitting on the back of the pump wouldn't work with my hose, so I took the fitting off the old pump and used it. They seem to be identical except for the depth for the hose fitting. My hose has the long tube with the o-ring on the end. Maybe I need a new hose?
Default Re: New PS pump not bleeding?
Old 04-29-2018, 06:41 PM   #2
I did the same thing with my pump donít worry about hose, you would have to change your ps box, is the pulley the same diameter as the old one? Sounds like itís spinning to slow
Old 04-29-2018, 07:07 PM   #3
JohnKcj5 is offline
JohnKcj5
Images: 2
New pulley is the same diameter. Could the belt be slipping without squealing?
What's the proper tension? Between the PS and water pump, I can spring about 5/8" play.
Old 04-29-2018, 07:37 PM   #4
Yes it could be slipping
Old 04-29-2018, 07:43 PM   #5
Iím on my phone right but your info will be in the FSM
https://www.jeep-cj.com/jeeplinks/gr...sm-online-114/
Old 04-29-2018, 08:05 PM   #6
JohnKcj5 is offline
JohnKcj5
Images: 2
Thanks. It specifies belt tension of 90-115 pounds. Can anyone do a measurement and tell me what you're running? Otherwise, I guess I'll just try tightening the **** out of it.
Old 04-29-2018, 08:14 PM   #7
Thatís a good way to rule out the belt give that a try
Old 04-29-2018, 08:36 PM   #8
Rep Power: 14 mtnwhlr is on a distinguished road
Sounds like a bad pump to me. Where did you get it?
Old 04-29-2018, 09:15 PM   #9
JohnKcj5 is offline
JohnKcj5
Images: 2
Summit Racing. Like I said, no belt noise. It just seems like a loose belt would squeal. Best I can tell, the belt tension is like it was before I took it off. It's at least as tight as the alternator belt.
Old 04-30-2018, 08:33 AM   #10
Send it back, and go to your local NAPA and get one there.
bleeding , pump
Lots of Bleeding rkcbvw Drivetrain 17 08-09-2014 09:28 PM
Problems bleeding my brakes Hamilton172 Suspension and Steering 11 10-21-2013 09:40 PM
Bleeding the cooling system-I6 duke94 Drivetrain 3 04-08-2013 05:51 AM
Brake bleeding problem dave123 Suspension and Steering 4 03-20-2011 08:30 AM
Ax15 Bleeding Problems Allen9878 Drivetrain 3 12-21-2010 01:09 AM
