Default Re: Lift Advice for 84 CJ7
Old 03-12-2019, 08:59 AM   #11
Eazyrider111 is offline
Eazyrider111
Vehicle(s): 84 CJ7, 258, T-176, D44, D30
Rep Power: 0 Eazyrider111 is on a distinguished road
I must have the WT D30. It looks to be factory welds on the shock mounts. I ended up mounting the shocks on the axle. Was attempting to kind of slap the front suspension together over the weekend but due to a family gathering on Sunday just didnt have the time or the parts. The OME bushing kits I purchased only come with one sleeve per pack. I read online that you reuse the sleeves from the front of the old leaf springs. Going to attempt to remove them with out a press. Burn, cut, drill? C Clamp and some sockets? What have you guys done in the past? Still waiting on one rear leaf spring and I ordered up some new ubolts F/R from Morris. I would love to post some pictures for you guys but every time I try it says Im not logged in? Maybe I have not posted enough times either? Anyway I will keep updating as I go.
Old 03-12-2019, 09:38 AM   #12
cglax6 is offline
cglax6
cglax6's Avatar
IIRC, my BDS bushings didn't have a metal sleeve for the front shackles. The rear bushings did, though. Or maybe it was the other way around...either way, my bushing kit didn't require me to use old parts.
I don't have any experience with getting them out, but I'd imagine tapping them out with a dull implement of your choosing would be ok. If you have a wide enough vise, you could use it as a press to get them out. If they've been in there for a while, it'll be a PITA to get out.
Old 03-12-2019, 11:27 AM   #13
RiverandSand is offline
RiverandSand
RiverandSand's Avatar
The old stock bushings have a metal outter shell which is usually rusted into the frame hanger eye. You will have drive those out and replece with new poly bushing which don't have a outter metal shell. Not sure what the engineers were thinking when they designed that setup. Just order up a new set of poly bushings for the front and back as most kits only come with the spring side.
advice , cj7 , lift
Lift Kit Advice for CJ8 wildcatmoto Suspension and Steering 15 02-25-2019 05:19 AM
SOA lift advice! Gclyne Suspension and Steering 38 02-09-2014 03:25 AM
Lift Kit advice stoney bones Suspension and Steering 2 03-02-2012 04:48 PM
Need lift advice 2.5 vs 4 clarythedrill Suspension and Steering 8 10-15-2011 01:59 AM
Lift kit help and advice for CJ-7 Canadian CJ 7 Suspension and Steering 21 06-23-2010 10:08 AM
