Default Jeep CJ-5 original suspension lift kit
Old 10-21-2018, 01:11 AM   #1
Tolu is offline
Tolu
Vehicle(s): '69 CJ-5, no engine yet, D27, D44
Rep Power: 0 Tolu is on a distinguished road
Hello
My first post... I own 1969 cj5 jeep. I live in Finland. Here car building is very hard because of law. Here maximum suspension lift is 3 inches unless there is some original accessory or suspension lift kit what Jeep offered when you buyed cj...
So i need some special model what i can compare in my jeep.
Is there any sppecial model for example two inches lift kit?
And sorry about my engllish, it is little bit rusty...
Default Re: Jeep CJ-5 original suspension lift kit
Old 10-21-2018, 09:13 AM   #2
Posi is offline
Posi
Posi's Avatar
Welcome,
The early CJ5s came with different spring packs. My 71 Renegade 2 came with 13/12 pack. The base model 69 CJ5 came with 6/5 from what I recall others optional models came 9/8. Between the base and optional spring packs there may have been up to an 1 1/2 lift, possibly 2.
Tolu (10-21-2018)
Old 10-21-2018, 11:43 AM   #3
Tolu is offline
Tolu
Okey.. do you have any literature about it? I have to show "proofs" when i register changes of car.
Old 10-21-2018, 12:02 PM   #4
Posi is offline
Posi
Posi's Avatar
The info is in the factory service manual (FSM)
In the FSM the F-head came with 7 in the front and 9 in the rear.
The V6 came with 10 in the front and 5 in the rear.
However, there's lots of variation in leaf count.
Jeep offered a standard and "heavy duty" suspension package for the entire run of the CJ-5
https://www.generalspringkc.com/Leaf...975_s/1950.htm
http://oljeep.com/53CjDj/53-71JeepCjDjServiceManual.pdf
I can tell you that my 13/12 leave pack in my 71 would cause your teeth fillings to fall out.
Hope this helps
Old 10-22-2018, 12:46 PM   #5
Tolu is offline
Tolu
That was helpful and and interesting. But most important distance is missing. I need to know height between frame and ground with highest suspension from factory.
A lot of leifs in your cj. I have only 4 per corner... My car have six inches lifting kit installed.
Old 10-22-2018, 01:22 PM   #6
Posi is offline
Posi
Posi's Avatar
Get out a tape measure and measure your Jeep.
If you have a 6" lift subtract 6" for stock height
Measure a leave spring, take that number and multiply it by however many springs you add on be it 5, 7. 9, or 13.
That is too tall for an 81" wheel base in my opinion.
Old 10-27-2018, 04:14 AM   #7
Tolu is offline
Tolu
It is too tall i admit it. That lifting kit was installed already when i purchased car.
I cannot measure height because car is now totally take apart. I need take all rust off and put v8 under the hood...
Old 10-27-2018, 08:09 AM   #8
Posi is offline
Posi
Posi's Avatar
Go to the link below you will find more stock CJ5's there, ask for measurements. Very friendly group.
ECJ5
Old 12-27-2018, 12:39 PM   #9
Grumpa is offline
Grumpa
Vehicle(s): '74 CJ5, 232ci, three speed, dana 20.
Grumpa's Avatar
Rep Power: 0 Grumpa is on a distinguished road
Hello
Give these guys a shot. Got my 2" lift kit there. Good stuff!
https://www.morris4x4center.com/a-na...ion-parts.html
cj-5 , jeep , kit , lift , original , suspension
Suspension lift done.??? oldyeller Suspension and Steering 13 06-14-2018 07:50 AM
Zero Lift Suspension Eam94 Suspension and Steering 6 05-17-2018 10:59 AM
Jeep TJ 3-inch suspension lift Im Not Spam Jeep News and RSS feeds. 0 03-14-2016 10:31 AM
New suspension - no lift or minor lift? 81CJ5Renegade Suspension and Steering 18 04-16-2013 08:42 PM
1inch body lift on 4inch suspension lift? Thoughts and issues. Austin Suspension and Steering 9 07-17-2012 08:32 PM
