Default hope this works
Old 11-11-2009, 07:49 PM   #1
Switch is offline
Switch
Images: 5
Rep Power: 0 Switch is on a distinguished road
So today after surfin the net for a bit I came across Rocky Road outfitters and found a high steer kit for my jeep, they say it will remove bump steer, on a spring over susp, and since the prevouis ower did the spring over and didnt address any of the steering issues, I think I may try this and see what happens, I kind of like the spring over thing, has anyone else tried this product or a simaler one? just wondering how it works, and also I found people saying to use chev truck brake lines up front to get alittle more lenght, so I ask is this true, or should I just go to the local off road shop and buy some, I usally dont mind spending the money but the shop in our citey sucks and can be rather greety, thanx Craig
Default Re: hope this works
Old 11-11-2009, 08:00 PM   #2
LongHorn is offline
LongHorn
LongHorn's Avatar
Images: 39
Rep Power: 13 LongHorn is on a distinguished road
I run a spring over setup with high steer on my rig. IMHO it's great. You can take your hands off the wheel at freeway speeds & I'm running 38" tires & over a foot of lift.
Old 11-11-2009, 08:04 PM   #3
Images: 220
I have heard th RR kit is pretty robust.
One of our members used their kit, unfortunately he has disappeared for a bit. Maybe if you post in his thread he will reappear again!
http://www.jeep-cj.com/forums/f19/high-steer-sua-1913/
http://www.jeep-cj.com/forums/f49/suggestions-1902/
Old 11-11-2009, 08:14 PM   #4
mhubacek is offline
mhubacek
Vehicle(s): WR450F, 68' CJ-5, 72' CJ-5, F250 POWERSTROKE
mhubacek's Avatar
Images: 58
Rep Power: 11 mhubacek is on a distinguished road
I have been eyeing that Rocky Road SOA KIT every since someone mentioned it on here. Looks like they make a great kit! I plan on buying the SOA kit, then purchasing the OTT High Steering kit from them, shortly after I get the SOA completed. I believe the SOA kit comes with the necessary brake lines. You might see what just they're brake lines seperately run for. I've also heard that chevy lines will fit.
Old 11-11-2009, 08:19 PM   #5
mhubacek is offline
mhubacek
mhubacek's Avatar
Images: 58
$31 a piece at Rocky Road for extended brake lines.
Hope it Helps!
http://www.rocky-road.com/jeepbrake.html
Old 11-11-2009, 08:19 PM   #6
elwood blues is offline
elwood blues
Images: 58
Rep Power: 15 elwood blues is on a distinguished road
I've used stuff from Rocky Road Outfitters before. I can not tell you about the high steer kit, but I am using the HD track bar on my XJ. I would recommend those guys to anyone.
Old 11-11-2009, 08:28 PM   #7
mhubacek is offline
mhubacek
mhubacek's Avatar
Images: 58
The brake lines for sale at RR say it accomodates up to 5" of lift, however, they're SOA kit 6.5" comes standard with those extended brake lines for $31EA. Not sure how much lift you have above the SOA, but sounds like they work.
Spring over axle lift for Jeep CJ 5, CJ 6, CJ 7, CJ 8, Scrambler
Old 11-12-2009, 01:08 AM   #8
Switch is offline
Switch
Images: 5
Awsome, thanx for all the info, I am going to order the highsteer kit tomorrow and I will have them throw a set of brake lines in as well, thanx again for all the info guys.
Old 11-12-2009, 07:43 AM   #9
mhubacek is offline
mhubacek
mhubacek's Avatar
Images: 58
Let us know how it goes, and take lot's of pics! I, along w/other's may be doing this RR OTT High Steering Kit in the future. Advice on your install would greatly help!
hope , works
Deal in the works... Bowbender Introductions 15 01-17-2013 08:16 PM
brakes.....hope its in the right forum tphin Suspension and Steering 8 07-01-2011 10:22 AM
hope someone can help me kelgorreeks Introductions 2 08-29-2010 06:59 PM
How a differntial works. CJ Video 0 08-19-2009 07:00 PM
