Default Re: Curved Dana 44 Tie Rod, CJ7 Steering Linkage
Old 04-03-2016, 06:49 PM   #21
Lumpy Grits is online now
Speed-Can you inspect the TR for what may look like a 'hit' from a a rock or such?
FWIW: That TR is not a deal breaker if all else checks out.
How's about given us more details on your find?
Old 04-03-2016, 07:04 PM   #22
Woolyworm is offline
Woolyworm
Vehicle(s): 1978 CJ7, 72 304,CJ T18
Woolyworm's Avatar
Rep Power: 9 Woolyworm is on a distinguished road
If the flip was done with inserts then you could potentially remove the inserts and install new ones from the bottom up to move the TR back under. But having it high is better to avoid smashing it.
Wooly
Old 04-03-2016, 07:44 PM   #23
SpeedRotate is offline
SpeedRotate
Vehicle(s): Seeking a CJ7
Rep Power: 0 SpeedRotate is on a distinguished road
The find so far; CJ7, AMC360, T176, Dana300, Dana44 front and rear, fairly clean frame and body. Suspension seems to be 2.5 with an 'ugh' 3" body, rolling on 35's. Eventually I'd like to drop the 3" body and increase suspension lift, either keep it SUA or go SOA. No plan to go taller than 35's. I wanted to get some feedback to make sure I'm not stepping into a problematic front 44. This steering geometry has my mind spinning. Thank you for all the comments.
Old 04-03-2016, 09:44 PM   #24
Do you have any SMOG issues to be concerned with?
Have you been able to drive it?
How's the 'rust-issue'?
Old 04-03-2016, 09:55 PM   #25
As Lumpy asked have you taken it for a drive? If it drives ok down the road I would not worry to much about it. IMO
Old 04-04-2016, 12:29 AM   #26
SpeedRotate
I may have identified the Tie Rod and Dana 44 roots. Found these IH Scout II Dana 44 photos. The Tie Rod is a match.
Now there's the Scout axle castor question.
Thoughts...
Old 04-04-2016, 07:18 AM   #27
mriplaybass is offline
mriplaybass
mriplaybass's Avatar
Can anyone tell me what is attached to Speed's shackles? It almost looks as if there are snow plow attachments connected to the inside of both shackles, which appear to be welded, and the shackles wouldn't be able to move! Or is it just too early in the morning, and my eyes are not focusing yet?
Old 04-04-2016, 09:03 AM   #28
Bass, I am thinking tow bar attachments, as on my spring shackles.
Old 04-04-2016, 11:22 AM   #29
tarry99 is offline
tarry99
Rep Power: 11 tarry99 is on a distinguished road
Originally Posted by SpeedRotate View Post
Hey Guys, I had to create a new account because I couldn't get logged back in, even after several password resets. This appears to be an ongoing problem here, frustrating.
Here's two photo's showing the tie rod end on each side. Tie rod is mounted on top. I agree with Lumpy Grits, the bends do appear intentional but still weird. Woolyworm mentioned the arm may have been drilled for a top mount. If this was done are new arms need to put in a straight bottom mount tie rod?
I appreciate everyoneís input on this steering linkage issue. I havenít pulled the trigger in making this CJ mine yet but Iím really close. Itís got the heavy hardware Iím looking for, I just want to know what Iím getting into here as Iíve never seen a tie rod like this. Also, no steering stabilizer, sloppy steering.
It's a Dana 44, I guessing from a wagoneer, CO/PO has no input. Five bolt lug pattern.
ÖI plan to redo the front shackle/leaf extensions off the frame. They are very robust just not as clean as Iíd like to see them.
These pictures are a little better but still not really able to see what is going on there...........First off the tie rod looks to be bent.........(Note:Take a look at Torx steering with the split Y tie rod end......this is a more conventional steering setup with the Drag Link in front of the tie rod the way it should be.)
In conventional front shackle steering the Drag Link must be in front of the tie rod for two reasons.......1) because the axle is moving forward under compression and most importantly 2) Is the steering arm ratio whereby the distance from the sector shaft on the Pittman arm to the Drag Link as compared to the distance from the center of the spindle to where the drag link attaches at the steering arm both have to be near equal distance's.......if not you will loose steering turn radius and also if its short at the spindle you will also loose leverage to turn the wheels.
Some better pictures would be helpful looking more closely at the spindle connections...........Good Luck on the purchase.
Old 04-04-2016, 12:26 PM   #30
Do think that "Speed" found the ans.
That rigging on the front bumper is for a tow-bar. Hope it's included with the Jeep.
cj7 , curved , dana , linkage , rod , steering , tie
Dana 20 shift linkage issues. FarmerRoger Drivetrain 8 08-06-2015 05:05 PM
Dana 20 Sloppy linkage Fix and repair Drivetrain 11 07-28-2014 12:36 AM
Dana 300 Shift linkage Greenmule Drivetrain 2 05-11-2013 09:50 AM
Steering Linkage - Dana 44 Swap Scramble Suspension and Steering 10 03-05-2013 12:55 PM
Dana 20 Linkage DLane Drivetrain 9 01-22-2013 07:31 PM
