Default Camber Adjustment
Old 07-05-2013, 07:53 PM   #1
IowaCJ5 is offline
IowaCJ5
Vehicle(s): 1969 CJ5
Rep Power: 0 IowaCJ5 is on a distinguished road
Is it possible to adjust the camber on a CJ5? If so, what is the best method? I recently changed/replaced the suspension and now my camber is way off.
Thank you
Default Re: Camber Adjustment
Old 07-05-2013, 08:18 PM   #2
csuengr is offline
csuengr
Vehicle(s): 1980 CJ-7 LT1 TF727 NP231-D300 Waggy D44's ARB's 35" tires
csuengr's Avatar
Rep Power: 9 csuengr is on a distinguished road
It is impossible to change the camber changing the suspension. The camber is built in to the axle. Do you mean caster?
Old 07-09-2013, 09:46 AM   #3
Jimbos76cj is offline
Jimbos76cj
Vehicle(s): 83 CJ-7.. 4" YJ springs front rear, J-10 44 front/AMC 20 rear,6 cy auto dana 300 35' bfg Done and gone!! Ask me about my head light upgrade harness!!!
Rep Power: 10 Jimbos76cj is on a distinguished road
camber can be adjusted slightly with special inserts that go into your knuckles but more then likely you did not affect it with the new suspension. Caster on the other hand is almost always changed when leaf springs are changed and longer shackles are used. To adjust your angle you have 3 options..
1 buy a set of steel degree shims
2 cut your spring mounts and turn your axle to where its correct then reweld them on
3 cut your knuckles free of the tube and turn em to the correct angle..
it would really help to know how you changed your suspension.
adjustment , camber
steering box adjustment mikemrq Suspension and Steering 3 12-29-2012 10:03 AM
camber correction on 79 CJ? jeepboy45 Suspension and Steering 16 10-20-2011 08:38 AM
adjusting camber angle oldguy Suspension and Steering 8 08-25-2011 12:55 PM
camber dalefan88 Suspension and Steering 15 09-18-2010 06:14 PM
camber? dalefan88 Suspension and Steering 8 08-02-2009 03:30 PM
