Default Re: Which brand of lift kit
Old 12-20-2017, 11:10 PM   #11
Dan77CJ7 is offline
Dan77CJ7
Vehicle(s): 76' CJ-7 4.2L/T-18/d20 d30sua/amc20soa M/T MTZp3 35/12.50/15s mc2100
Dan77CJ7's Avatar
Rep Power: 7 Dan77CJ7 is on a distinguished road
Originally Posted by oldyeller View Post
So you recommend Rough Country or Superlift?
Are you on a budget?
Old 12-21-2017, 12:27 AM   #12
bluesman423 is offline
bluesman423
Vehicle(s): 1977 CJ5 258, Dana 300 with 4:1, SM420, 3.54 Dana 30 and AMC 20 1981 CJ7, 151, SR4, Dana 300, Dana 30 and AMC 20
Rep Power: 0 bluesman423 is on a distinguished road
Not sure about Superlift on a Jeep, I tried a 6" Superlift on a Dodge and it was great.
I have had two 4" Rough Country lifts on CJ7s and liked both of them.
Old 12-29-2017, 09:21 AM   #13
oldyeller is offline
oldyeller
Vehicle(s): 1980 CJ7 Renegade 304 2bbl Dana 30 / AMC 20 3:54-1
Rep Power: 0 oldyeller is on a distinguished road
Thanks for your input guys, sorry to go off the scope for a while. Back to topic. As everyone, I would like to get as much for my money as I can, but budget won't stop me if there is a stand out, hands down, winner in the lift kit world. Some of the most complete kits have been Rubicon express. But the price is triple. It jumps from 500 to 1600. Like I said, it has everything, brake lines, degree shims, shocks, drop arms, etc. I think I need to research more because some of the kits mentioned here I have never heard of. Thanks for your help.
Old 12-29-2017, 11:00 AM   #14
R717 is offline
R717
Vehicle(s): 86 CJ-7, 258, junkyard HEI, Weber DGEV, T5, D300, D30/D44, OME YJ lift springs, BFG 33x12.5 A/Ts
R717's Avatar
Rep Power: 0 R717 is on a distinguished road
I think it's overkill for me because I'm not gonna be trail riding or rock crawling.
I think we'll be able to offer better help if you define your goals, what you plan to do with your jeep and your constraints. (E.g. trying to fit 33s, doing mud bogs but also need good street manners, not cutting fenders, don't want to go to YJ springs, etc.)
With 4in you'll have to address driveline issues which adds a bit to the budget. There is a chart floating around from JP magazine that shows what lift is needed for what tires, but you can get away with more tire and less lift depending on your use.
Old 12-29-2017, 11:09 AM   #15
oldyeller
No rock crawling, mud bogging, may trail ride occasionally. i have given thought to 3" suspension and 1-2 body lift. wheel spacers for help on clearance.
Old 12-30-2017, 01:41 PM   #16
Peanut Butter is offline
Peanut Butter
Peanut Butter's Avatar
Images: 37
What size tire are you wanting to run? Sounds like that is the driving factor here if your needing a 5" overall lift. There are a lot more factors to consider when you lift a CJ. For a daily driver and some trail riding, 5 inches of lift is a lot. With that you have to consider your axle angle, driveshaft and u-joints. You'll also need to take a hard look at your steering components. Maybe you'd be better off going with a slightly smaller tire that still looks good, but allows you to use a 2 1/2 inch lift. This way you are not stressing your drivetrain components or your steering setup. There are several threads on here about the other things that come into play with several inches of lift.
Old 12-30-2017, 06:54 PM   #17
33's would do you well then. Forget wheel spacers.
What's your R&P ratio? What tranny are you running?
Do you still have the OEM 2-piece axles in the rear?
Old 12-31-2017, 12:46 AM   #18
HackFabrication is offline
HackFabrication
Vehicle(s): 1976 CJ5, 2020 Grand Cherokee Summit, 2018 GMC Sierra 1500 SLE Regular Cab Shortbed
Rep Power: 12 HackFabrication is on a distinguished road
If your intent is to run 33" tires, and run mud, then you need to be 4.10 gears in the axles. Running mud is all about wheel speed, and it's going to be hard on the Dana 30 front end. If you've beefed up the AMC20, then you should be okay with 33's.
Honestly, without the articulation issues of crawling rocks, you can get by with a 2.5" lift and a 1" body lift.
I'm running a BDS 2.5" lift on my 76 CJ5 with 32" TSL/SX tires. And honestly, the BDS warranty is tough to beat.
"In the end...It's all Hack."
Old 12-31-2017, 10:33 PM   #19
oldyeller
Once again I really appreciate the response. I have the oem Dana 30 front and AMC20 rear running 3.54 r/p. Open diff. Still 2 piece axles. i just finished replacing every rubber bushing in the sway bar and the suspension. This helped my drift problem considerably. It still gets a little squirrelly after hitting bumps in the road but that may be normal. I have no problem with it but I'm trying to get it ready for my 16 year old daughter to drive occasionally. She tried it when I first brought it home and at 20 mph we were all over the road. Finally making progress. Happy new year everyone!
Old 12-31-2017, 11:26 PM   #20
Getting squirrelly when hitting bumps on the road is probably due to tired rod ends, it is not normal.
brand , kit , lift
Brand new CJ7 owner Loki Introductions 22 05-26-2015 10:49 AM
Anyone Knows Any Other Brand? seyit Misc CJ Discussion 1 12-07-2011 09:32 AM
Brand new Member MyOldJeep Introductions 2 11-10-2011 05:52 PM
Brand-new member ThumperFox Drivetrain 3 05-25-2011 03:31 PM
Lift: What brand to buy? 2.5" lift northfaceboy22 Suspension and Steering 11 08-25-2009 11:03 PM
