Default brakes.....hope its in the right forum
Old 06-27-2011, 04:40 PM   #1
tphin is offline
tphin
Rep Power: 0 tphin is on a distinguished road
have an 83 cj7,all of a sudden the brakes are acting funny.when i initially hit the brakes the pedal is fine but within a few seconds starts to get soft and will eventually go to the floor.its not leaking fluid any where i can see,im stumped
Default Re: brakes.....hope its in the right forum
Old 06-27-2011, 06:18 PM   #2
is the resivoir level dropping?? I would suspect the master cylinder.
Old 06-27-2011, 07:01 PM   #3
Rep Power: 18 Old Dog is on a distinguished road
I agree with IO
Old 06-28-2011, 06:08 AM   #4
tphin is offline
tphin
No it has not dropped
Old 06-28-2011, 03:53 PM   #5
reckless is offline
reckless
Vehicle(s): !977 Cj5 , 2B 3000cc , Diesel
Images: 32
Rep Power: 0 reckless is on a distinguished road
I have the similar problem..At 1st press padle is very soft and works good but eventually it gradually hits the dead end . But at the same time it is very sensitive.
1) check the master cylinder and caliper cylinder ratio.
2) check the rubber pipe attached to brake lines it might be to old.
3) valves ratio .
4) it might be the gap btw wheel drums and the brake pads . try to adjust them or change the drum if necessary.
5) The route of brake lines . if they are passing thru the are which gets hot like exaust pipe , it might be heating up brake fluid.
Old 06-28-2011, 08:25 PM   #6
Listen to IOPort and OldDog. A couple of the more experienced jeepers on this site.
It's a problem with the hydraulics not the mechanics of the brakes.
It's the master cylinder.
Old 06-30-2011, 06:38 PM   #7
dpuck is offline
dpuck
Vehicle(s): 78 CJ7, stock 304 with Eldabrock 600 4 bbl. carb., Dana 30 front, T150 Trans, Dana 20 TC and rear axle, Warn 8000 winch. Original paint, running 31's on original spoked wheels. 2 1/2" lift springs with 1/2" lift heavy duty shackles.
Rep Power: 0 dpuck is on a distinguished road
Yep, I've seen it a hundred times when I worked in the garage.
Old 06-30-2011, 09:45 PM   #8
73CJ is offline
73CJ
73CJ's Avatar
Images: 61
Rep Power: 13 73CJ is on a distinguished road
Internal leakage of the master cylinder. Check for pits in the piston bore. Brake fluid likes to absorb moisture and pit the bore. I switched to silicon fluid and end of failing master cylinder.
Old 07-01-2011, 10:22 AM   #9
JR74CJ5 is offline
JR74CJ5
Missing-Presumed Wheeling
JR74CJ5's Avatar
Images: 80
Rep Power: 12 JR74CJ5 is on a distinguished road
We just replaced the Master Cylinder last night on my Uncles CJ.
Same problem, and fixed the solution...
~ JR
JR - ECV3
My Build< Click me
brakes.....hope , forum
Manual Brakes to Power Brakes grunt Misc CJ Discussion 26 05-19-2013 11:07 PM
cj7 brakes paparooster Misc CJ Discussion 14 06-24-2012 03:01 PM
hope someone can help me kelgorreeks Introductions 2 08-29-2010 06:59 PM
hope this works Switch Suspension and Steering 8 11-12-2009 07:43 AM
