Default Advice on lowering CJ7
Old 06-16-2018, 12:48 PM   #1
NFD EN21 is offline
NFD EN21
Vehicle(s): Ď80 CJ7,350,400 turbo,Dana 300,D44,D44
Rep Power: 0 NFD EN21 is on a distinguished road
Need some opinions, Iíve got an 1980 CJ7, spring over ,lifted,on 37s. Iím going to but it back to more street friendly, spring under, with a 4in lift and 33s. My question is what order should I do it in. I know Iíve got to have the spring perches moved. Do I need to have the lift kit ready to mount when I have them moved?
Default Re: Advice on lowering CJ7
Old 06-16-2018, 12:59 PM   #2
JeffP is offline
JeffP
Vehicle(s): '75 CJ5, 304, T18, D20, D44s w/3.73 1974 CJ5, 304, 4 spd., Dana axles 3.73 gears. 1973 CJ5, 258 I6, T18, Dana 20, Dana axles 4.27 gears. 1972 CJ5, 304, 4 Spd, Dana 20, 4.27 gears. 1976 CJ5, 304, T150. 1976 CJ5, 304, T150, J20 w/4.10 gears. 69 CJ5 Hurricane 4 cyl, 4spd all original! Ď53/Ď54 M38a1 100% original but also 100% apart! Low 3 digit Vin! One of the very first m38a1s!
JeffP's Avatar
Images: 27
Rep Power: 3 JeffP is on a distinguished road
I suspect you will need the lift installed before moving the perches. You need VERY accurate measurements to get the caster angle and driveline angles correct.
All mine are stock height with 31Ē tires. VERY nice on the street / highway and plenty of clearance / traction offroad. Save yourself time money & work. Leave it stock with 31s.
The last time I was stuck was in the late 70ís with skinny factory tires in mud. Pretty funny... the guy that rescued me had to winch himself into where I got stuck then winch himself back out!
Traffic cops are just Jeep herders.
Old 06-16-2018, 04:06 PM   #3
NFD EN21 is offline
NFD EN21
Thatís what I was thinking. Also doing an engine swap, Q4 6.0 replacing a 350. Figure Iíll need that done first before the lift to get the angles also.
Old 06-16-2018, 05:32 PM   #4
When you set the front and rear pinion angles. Make sure the springs are under the jeeps weight, and remember the springs are going to 'settle'(flatten out)some.
JeffP (06-16-2018)
Old 06-16-2018, 10:59 PM   #5
jp360cj is offline
jp360cj
I would have the lift kit ready to put in. The perches need to be tacked on, then text fit with the new springs in SUA configuration, then the perches may need to be adjusted to get the caster /pinion angles correct.
What gears and axles do you have with the 37s? If it's been properly regeared for the tires, it may end up being too low with the 33s
Old 06-16-2018, 11:51 PM   #6
JeffP is offline
JeffP
JeffP's Avatar
Images: 27
In the real world, they donít even need to be tacked. As Lumpy pointed out, the suspension needs to be loaded for accurate measurements. The U bolts will hold everything in place well enough to measure, adjust & measure again. Then simply mark them or tack them in place. Take it apart, do the final welding & painting, then reassemble.
The Following User Says Thank You to JeffP For This Useful Post:
jp360cj (06-16-2018)
Old 06-17-2018, 07:56 AM   #7
NFD EN21 is offline
NFD EN21
Itís got Dana 44 front and rear. Itís gonna have to be revealed, Iím putting a 6.0 in it and using it for mostly street.
Old 06-17-2018, 11:14 AM   #8
JeffP is offline
JeffP
JeffP's Avatar
Images: 27
If itís intended primarily for street use, why is it lifted at all?
Talking Re: Advice on lowering CJ7
Old 06-17-2018, 11:52 AM   #9
Way easier, to get in and out of the mall parking lots.
Old 06-17-2018, 12:31 PM   #10
NFD EN21 is offline
NFD EN21
The PO had it lifted and 37s for off roading. Iím redoing it and I like the look of the 4in with 33s.
advice , cj7 , lowering
Lowering Suspension DosCaras Suspension and Steering 12 06-11-2014 05:04 PM
Lowering a soa lift... jasonmark1993 Suspension and Steering 14 09-18-2011 11:30 AM
Lowering a cj7. NorCalChris Suspension and Steering 6 05-01-2011 10:20 AM
Lowering Seats KenB Chassis and Body 23 01-01-2011 10:37 PM
Long-Arm Lowering Kit Im Not Spam Jeep News and RSS feeds. 0 10-29-2010 05:50 PM
