Default 2 Bolt or 6 Bolt steering knuckle?
Old 12-19-2019, 10:12 PM   #1
JeeperChris is offline
JeeperChris
JeeperChris's Avatar
I'm buying some new front rotors for the '79 CJ5 and the site is asking if I have 2 Bolt steering knuckle or a 6 Bolt.
I think it's a 2, but what am I looking for? Anyone know for sure?
Default Re: 2 Bolt or 6 Bolt steering knuckle?
Old 12-20-2019, 08:48 PM   #2
JeeperChris
Ok, so I found out this is referring to the mounting of the caliper bracket to the steering knuckle. '78 seemed to be the change over year, earlier had a 6-bolt bracket and later had a 2-bolt bracket but there was some overlap due to them still having parts laying around, so I have to check my particular Jeep to be sure......... when ever I get it back from my mechanic.
Old 12-20-2019, 09:40 PM   #3
Patrick is offline
Patrick
Patrick's Avatar
I still canít figure that out. The caliper bracket and the caliper are joined by two slider bolts. The caliper bracket mounts solidly to the steering knuckle with two bolts. That is all I know. Please post a pic if your setup is different. I donít want to miss out on this.
Old 12-20-2019, 09:56 PM   #4
JeeperChris
So if you were to order new brake rotors you would get the "2-bolt" kind because yours bolt up to the knuckle with 2 bolts. I still have to wait till monday when my mechanic opens the shop again to find out what mine is.
Old 12-20-2019, 10:23 PM   #5
Posi is offline
Posi
Posi's Avatar
Your 79 is a 2 bolt
79 FSJ is 6 bolts
JeeperChris (12-20-2019)
Old 12-21-2019, 03:56 PM   #6
Patrick is offline
Patrick
Patrick's Avatar
I see. The six bolt then means that the mounting bracket is removable from the knuckle, not referring to the caliper bracket. Please correct me if I am wrong.
Old 12-21-2019, 11:27 PM   #7
Posi is offline
Posi
Posi's Avatar
That is correct
Old 12-22-2019, 10:23 AM   #8
Patrick is offline
Patrick
Patrick's Avatar
Right on 👍
Old 12-22-2019, 04:02 PM   #9
JeeperChris
Here are the rotors I ordered:
https://www.r1concepts.com/detail_ca...otor+silver+++
Old 12-22-2019, 04:04 PM   #10
JeeperChris
And as soon as TSM gets back to me about the rear disc kit I'll be purchasing that too.
bolt , knuckle , steering
Power steering bolt. RiverD69 Suspension and Steering 8 06-23-2014 08:59 AM
78 manual steering box bolt pattern RayDan Suspension and Steering 3 06-04-2014 11:58 AM
82 cj7 steering stabilizer u bolt question 1970 beepbeep Suspension and Steering 1 09-16-2012 03:05 PM
Stock shackle length bolt to bolt? suburban99 Suspension and Steering 10 01-27-2012 04:39 PM
what GM steering columns bolt into CJ7??? mobypinkie38 Suspension and Steering 15 01-01-2011 04:06 PM
