What's this mean?
It's on the top end, near the rear. I've only gotten plug 5 and 6 out so far, 5 looks good, 6 is black and full of carbon. I've been meaning to do plugs so will get the rest out and try that. Hopefully I'll know more tomorrow (busy weekend here)Ouch - Its hard to say over the internet, but I'd listen by the oil pan to see if it's a rod, or look for a front end physical clearance issue.
Also, power steering pump or oil low?
Plug was more dry crusty black, idle speed in the video was around 1800 since it was still cold (about 30 f in the garage this morning). Drove fine last night and started up this morning with that noiseMeant to add if the plug looks sticky black goo it’s more than likely head gasket related which can get worse sitting overnight in cold temps.
Exhaust port will get gummed up and hang open.
The time of the sound and tone is off for a lifter- not sure what your idle speed is
Yeah, I pulled it to try to hear if it was a backfire. She's my daily driver.Was the air filter on last night? I know it’s not in the video. Mouse could have crawled in there
Just troubleshooting. I had just changed oil and air filter a couple weekends ago.When you had the air cleaner off looking for a backfire-is this a normal thing or just troubleshooting?
A worn rod seal or incorrect rocker torque can lead to this issue
I just ordered rockers, pushrods, and a couple lifters though I'm not sure I'll be able to get them out with the head on but they were cheap so I threw them on the order. Now the week wait for Rock Auto...
DrDoc
Any way to check that without pulling the cam or head?Primary question to answer before you dive into it.....why did the pushrod come loose in the first place? My guess is you have a flattened cam lobe. Would hate to see you repair everything and then just have it happen again after you start it up. Good luck.
