Transmission Help
aglinks
I had a clunking/knock coming from the bellhousing only when he trans was in neutral. I replaced the flexplate because I found some minor cracks and installed a new converter and new transmission filter. I started the jeep today and it made horrible noise for the first millisecond and barely moved when in gear (acted like the converter wasn’t seated and I KNOW it was). When I put the jeep in reverse it stalls the engine and the starter has a hard time engaging after it has stalled. Any thoughts?
