Transmission help
Cjordan
Good afternoon folks. I had some issues with the jeep earlier today and can't figure out what's going on so hopefully y'all can help.
I was pulling into a buddies drive way and was going to circle around then back into place. I was still moving forward just a little when I tried to grab reverse. While doing so the transmission wanted to grind a little so I came to a complete stop, shifted on into reverse and eased off the clutch, but she wouldn't move. You can shift through all four forward gears or reverse and she still won't move. You can shift through gears with or without the clutch pressed in. I have tried cranking it in gear, I have went from 2hi to 4hi to 4 low but still nothing. Just wondering if this is something some of you may have ran across in the past?
Any and all help is greatly appreciated. Also when in 2hi I can spin the front drive shaft but once I shift to 4wD you can't spin it anymore
