T176 Trans Rebuild
loootninja
- Raleigh, NC
- 1980 CJ5, Inline 6 cyl. AMC engine, T176 Transmission, Dana 300 Transfer Case
Greetings,
I'm rebuilding my T176 transmission for my 1980 CJ5. I've never rebuilt one before, so there will definitely be questions, and I thought I'd use this thread to consolidate them and hopefully it'll be useful to others when I'm done.
First, a little back ground. The jeep's been sitting for a about a year. I had just removed the transmission and transfer case (Dana 300) while in the process of replacing the rear drive shaft u-bolts and installing a Novak hydraulic clutch link conversion when I was forced to leave town on business for about a year. Now that I'm back, I need to get this thing running again. The transmission shifter wouldn't run through its gears and when I drained the fluid there was a good amount of water in the transmission.
I bought a master rebuild kit from Novak and just opened the transmission up last night. In the process of doing so, I put a hole right through the shift control lever housing assembly cover (pics coming later). So first question: can I weld this and grind it down? A new cover costs ~$!70
