• The site may intermittenly be closed or unreachable due database issues and the gallery / downloads are currently offline. Sorry for the inconvience.
Electrical Step on the brakes....about every light BUT the brake lights come on??
hoofmender
Arizona
1977 CJ5
Hey all...... On my '77 CJ5 , when I step on the brakes, I get no brake lights but the front parking lights, side marker lights, and the in speedo head turnsignal indicators all light up... any ideas? Thanks, Dave
CJ wiring is finiky. If this just started, almost all problems can be traced to poor grounds. I would start there..
Thanks guys. I suspect grounds or I was told the directional signal switch? Those have never worked since I’ve owned it. ‘77 Levi (Edition) ’s CJ5 that the previous owner had for 38 years. Hadn’t run in 3-4 years. I’ve got her running great now. Still have some electrical gremlins. Thanks
Didn't know the turn signals did not work. That could be part of the problem, time to get a DVM and a schematic and start working from the tail lights forwards...
Depends on how many times the lights have been replaced and with what type. Factory ground is light to the tub. Many ground issue problems are fixed by adding / cleaning / checking grounds from bat to frame / engine / main tub / fenders / dash / each light / grill / steering column etc.
A good test is to run a long wire from neg battery and check each light one at a time.
It sounds like someone installed the wrong flasher. If you have LED bulbs they require an electronic flasher. If the bulds are mixed, some LEDs & some incandescent bulbs the flasher can get confused.
Brakes 10 or 11
