Rocker arm options-77' V8
duke94
I'm rebuilding the 304 in my 77' and need to replace the rocker arms as they are used up. Is there something a little more modern to replace the originals with?
these are the ones i bought you will need to check your studs to see if they have a 5/16 or 3/8 stud on them first
http://www.summitracing.com/search/...tOrder=Ascending&keyword=scorpion rocker arms
I like those. Mine has 5/16 bolts holding the pivots in place. What did you use for studs?
