Rear wheel arch dimensions PLZ
DieselJeep
Hello everyone,
I am almost done with the project, but the last metal I have to fabricate for the tub is the rear wheel arches. A PO bubba'd them pretty badly. Cut so far as to get into the earlier fuel fill stamping, and even the triangle "dip" at the top edge where tops mounted originally.
I have searched exhaustively, and other than a few pics from too far away I haven't had much luck. I don't have access to a stock CJ5 or m38a1 either.
What I am hoping for is diameter dimension across the arch above the trailing edge radius, and the diameters of the leading and trailing edge radius as the trailing seems about half of the forward radius. Also, exact measurements to the arch from other stampings, such as the triangle top dip, early fuel area stamping, ect.. Maybe from what stamping as soon as it is flat on the vertical? Hope this makes sense to somebody haha.
Mine is a '74 CJ5, and want to return the arch to 100% stock dimensions.
If you can share nice reference pics with dimensions, in advance:
Thanks!
Thanks!
