• The site may intermittenly be closed or unreachable due database issues and the gallery / downloads are currently offline. Sorry for the inconvience.
Electrical Pairing down factory wiring harness
Manic Mechanic
Full Time Jeeper
Gold Supporter
Featured
Thurmont MD
85 CJ7 4.2L 258 .040 over, T-5 trans, dana 300, dana 30 front 3.23 and lock right locker, rear amc 20 3.23 one piece axle shafts traclock
79 CJ7 304, th400 auto borgwarner 1389?? qudratrac stock rest unknown.
89 YJ 4.2L 258, AX-15 5spd, NP231, dana 30 front, dana 35 rear with posi, gears unknown
92 YJ 4.0, AX-15 5spd, np231, dana 30 front, dana 35 rear.
So one of the things I love best about not living in comi fornia is getting rid of useless and power robbing emissions components and what not. So I'm basically making my own wiring harness at the same time. But I have no clue what the purple and gray wire coming from the fuse block go to. The gray has a factory end on it the purple has just a female connector.
Yes I know it's a rats nest hence the removal. plus I found terrible splices wrapped in duck tape. I wish people would stay away from things they don't how to work on 4a0d815c5b499d452305c5973e97b53a.webp 0bb1f2b828145a568e7500d4341ea361.webp 38c7b16e6f995f5887d92410b7ea6dd8.webp 06672bfda415d9474cb72ae3b3b16e81.webp 8d4d3e1c3dfc62cf5054f3f64707329e.webp dc192130158417a7bf77d203cbd45818.webp 6faf9894d9cb60690f9f7f85f30b1eff.webp 9a6283605df61e332ff147d88f533ba2.webp
In the engine bay, the purple goes to the oil pressure sender and the gray was on the alternator (tee'd to another gray connecting to the voltage regulator) for the charge light indicator in the dash (upper right and far lower left in the pic).
The duct tape covered splices are factory. :D
Thanks makes sense. Neither are in use any longer but I'll keep the purple just in case
Duct tape and zip ties - the home mechanic's best friends.
Thought that was a sawzall and bondo
In any case I'm just waiting on my new wire loom and I can put it back together. All duct tape splices gone
One of the best thing any CJ owner can do is untape, cleanup, and solder all the splices where Jeep originally simply crimped and then taped then up.
Actually I crip mine with built in heat shrink tubing same as aviation repair guide lines
When I did my fuel injection and engine swap, I pulled the entire wiring harness (engine bay, under dash, and rear) and laid them out on the dining room table. Removed all the tape and loom, inspected, soldered, replaced a few connectors, added some actual wired grounds, and then re-wrapped with plastic loom before re-installing. Some work, but WAY cheaper than a new Painless or other harness, stock wire colors retained for future reference and using a shop manual, no more crimps or butt splices, and I know that harness inside and out now. Fuel injection, ECM, electric fuel pump, and remote start/alarm circuits are all built-in and look stock (other than knowing none of that came with the Jeep).
TS, you take the quality of your work to high standards, and I commend you for that. With that in mind, if you had to crimp terminals to cable ends, what crimp terminal style would you recommend…
I like these with built in heat shrink tubing d9cb05134c5cf2e42c6b0970c48b70a6.webp
Manic is right. The connectors with buil-in heat shrink are great. I prefer the Ticonn brand. They have lugs, butt splices, spades, and rings. I also use their ratcheting type crimper. The ratcheting function is better than just a squeeze type because you have to get it all the way crimped before it will release. All available on Amazon. But to tell the truth, I usually solder even crimp on terminals.
I have more work to do on the fender (add ONS lights horn fan etc) but the main harness is done 539f1d1ac76f4d826ba8e16c6aefae98.webp e24b0e2160b74bc81df1f30c817c1656.webp
Where do you have it mounted on the Jeep ?
On the side of the battery tray. Still trying to figure out where I'm going to mount the ground one like it. If you look at the one pic I posted with the wiring harness you can see it tucked up in the very top right corner of the Jeep (left side of the picture)
Here's the ones in using and a pic of the power block 4bbf53f6d35d14faf9bb64532b18cd31.webp 713a3e5b51808c9c08e2216ad8deea5d.webp
Ok I missed it in that one picture. I have some connectors like those I found along the way. Didn’t realize they were heat shrink. I don’t have an industrial heat gun. What are you using?
Brakes 10 or 11
