Cut and paste from a chevy truck forum:
What the EGR system does and when:
The EGR system allows exhaust gas to be introduced into the intake stream in order to cool combustion chamber temperatures under load. This reduces NOx emissions and helps prevent pinging (detonation.) The EGR valve is closed at idle. On throttle application, the EGR valve will be commanded open by the PCM as needed.
How the PCM tests the EGR system:
The PCM waits for many conditions to be met before running the EGR test. From 1994 factory manual: PCM must be in closed loop, above 32 MPH, throttle position 10% to 25%, steady throttle with no more than 2% change, MAP reading above 47.5 kPa or below 15 kPa, maximum short term fuel trim less than 6 counts for 3.2 seconds, desired EGR command greater than 93%.
In simple terms? This tends to happen when you're cruising on flat ground on the highway.
At this point the PCM will momentarily de-energize the EGR solenoid to close the valve. The PCM watches the fuel integrator counts to see if they increase compared to normal EGR operation. If it fails twice in a row, code 32 is set and check engine light is illuminated.
Possible symptoms of EGR trouble:
- Rough idle and rough part throttle operation (valve opening too easily or stuck open)
- May stall during transition from idle to part throttle (valve opening too easily or stuck open)
- Noticeable pinging (detonation) especially when engine is under load (valve inoperative)
- Trouble code 32 (valve inoperative)
- Hard or no start although fuel and spark are present (valve stuck wide open)
Possible Failure Modes:
- The vacuum supply from the TBI unit to the EGR solenoid can be disconnected, broken, clogged, or incorrectly connected
- The EGR solenoid can be faulty or the electrical connection to it can be missing or damaged
- The vacuum supply from the EGR solenoid can be disconnected, broken, clogged, or incorrectly connected
- The EGR valve can be faulty, clogged, or the incorrect part for the application
- The EGR passages in the intake can be clogged with carbon
