Frame flex and front end shaking '64 CJ6
JamestheJeep
- Lake Elsinore, CA
- 1964 CJ-6 with Dauntless V6, 2005 Jeep Liberty Diesel, 2007 Jeep Wrangle JKU
Hello. I'm new to the CJ5/6 world. My 1964 CJ6 when I'm driving 40mph+ shakes from side to side in the front end. Also, the steering wheel shakes intermittently. I figured this could be a number of things such as all of the steering linkage needing to be rebuilt, could be tires, and could be wheel bearings. Any thoughts? All of this is going to be redone soon.
What concerns me most is something that I observed with the frame. I had my son sit in the driver seat and cycle the steering back and fourth as I lay under the Jeep to watch the linkage and steering components. I was checking for worn rod ends, knuckles etc. I only found that the pitman arm nut was loose. So anyway, as he would pull the steering one way, the whole frame would pull that way from about the fire wall forward. When he went back to center, so would the frame. When he went the other way, as did the frame again. IS THIS NORMAL? Is the frame that weak in the CJ5/6 or do you think I have a problem?
