Common 4X4 myths
BusaDave9
Always Off-Roading Jeeper
- Durango, Crawlarado
- 1979 Jeep CJ5 with 304 V8, T18 Transmission, Dana 20 Transfer case with TeraLow 3:1 gears, 4.88 axle gears, Detroit Locker up front and Ox Locker in back with 1 piece axle shafts, 36" SuperSwamper SX Tires, Shackle reversal, MileMarker Hydraulic winch, MSD 6A ignition.
Myth #1: I often hear it said that an open differential will, at times, send all the torque to the one tire with the worst traction. And that a locking differential (or spool) is needed to send torque equally to both tires on an axle.
The above paragraph is almost completely opposite from the truth. Actually an open differential will always send torque equally to both tires on an axle. And a locking differential can, at times, send all the torque to the one tire with the best traction.
As an example lets say you have a 2 wheel drive car with 2 tires on dry pavement and the right tires are in snow and ice. If the car has an open differential and the driver were to hit the gas he would just spin his right tire and he wouldn't go anywhere. Some would say the right tire is getting all the torque but actually it is getting very little torque. It doesn't take much torque to spin a tire on ice. The tire on dry pavement is getting exactly the same amount of torque. An open differential will always send torque equally to both tires.
Now if the car had a locking differential he would be able to accelerate quickly. The left tire would account for all the acceleration because it would be getting all the torque.
I hear this myth stated incorrectly on a regular basis in books and magazines.
For an explanation of this myth click here: http://www.jeep-cj.com/forums/f49/common-4x4-myths-11138/index9.html#post134587
