Closed knuckle Dana seals
SlightlyBurntOut
- South Central PA
- 1965 CJ-5... Hurricane 4-cylinder looking to do a factory-condition restore. Many other Jeeps through the years including YJ, XJ, and still have a very nice LJ.
Good evening Gentlemen
Im new here so be easy on me. I am a 3rd generation die-hard Jeep lover that has just recently entered the world of CJ5’s when I recently acquired a 1965 model, F-4 and 3 speed trans. I am planning a restoration to make it look as factory and stock as possible within reason. I have not had the chance to really dive into it head first yet but on Saturday I did manage to get it into the shop and roll around under it for a few hours and begin assessing things.
Mechanically things are very sound, it spent most of its life on a car lot as a yard donkey and snow plow unit. The steering is VERY tight, surprisingly, only about an inch or so of play in the steering wheel. I spent the afternoon greasing every linkage I could find and looking things over.
One thing that really caught my eye was the closed knuckle joint on the drivers side is weeping oil pretty good. I’m not sure which model Dana this is so perhaps someone here will know. Now, first tell me how these work... it has what appears to be a fill plug so I would assume that gets filled to the run over point with some kind of light grease or heavy oil?
Second, what all is involved with replacing the seal? I have looked at the kits on Omix-Ada and EBay but cannot find any installation sheets. Can these be installed simply somehow from the inside without pulling the hub and all that jazz?
I’ve also seen some kits with the kingpin bearing assemblies, with steering as tight as mine do you perhaps think that part could be skipped or is it best to do it all at once. When the front axle was up on the jack I forgot to grab a bar and see if there was any play in the kingpins but I really should do that.
Thanks for your help. I’m sure this has been addressed here before but didn’t find much in the search. I’m sorry, it won’t let me post photos for some reason.
