i cant get the caliper off because one of the caliper bolts is trapt by the bolt thru the banjo fiting?
A 79
should only have one bolt securing the
support key, which is in turn bolted to the Anchor plate. No bolt
should go through the caliper at all, except the banjo. Sounds like somebody swapped in something else, at one point. Got a pic?
Are the bleeder screws trashed? Is the bleeder seat trashed?
Are you using a
vacuum bleeder or "Suction pump" by chance? If so, some teflon tape on the
outer few threads only will keep air from entering
in through the threads, and getting sucked back out through the bleeder hole. This "no suction" condition is common with vacuum bleeders.
If you go this route, be careful go slow. You DO NOT want any bits to get inside the tapered seat area. Cut tape to width, if necessary.
The
threads aren't designed to seal against hydraulic pressure, or incoming air from a vacuum source on the bleeder screw. The tape will not effect the bleeder screws operation at all.
The
tapered seat is what seals the bleeder when tightened, Not the threads.
Many replacement bleeder screws and "speed bleeders" come with that painted on thread sealant for the same reason. That paint on plastic sealant would be ideal, if you can find some. I couldn't. I use tape instead. Maybe you could buy the replacement bleeders with the sealant already on them if teflon tape on your brakes sounds scary or unsafe to you.
And keeping with jasonmarks response and question. The bleeder is at the top or higher than the caliper piston, correct? If not, the left caliper and right caliper are on the wrong sides. Swap them around and use new sealing washers when doing so.
If the jeep was lifted, someone might have swapped caliper sides, instead of buying longer brake hoses. Plan ahead for this as well if the calipers seem to be on the wrong sides.
