bolt removal 101
rr41mag
Full Time Jeeper
- Panama city florida
- 04 dodge truck, 1966 chevy truck, 2012 rav4
And finally a 1981 jeep cj7 258 hardtop
This seems to be a very popular topic so I couldn't help but put my .02 worth.
First off I did 15 years in the air force machine/welding shop. A majority of which was removing screws, bolts. I had everything from 10/32 dry bay panel screws, fuel cell panel coin slots, landing gear bolts, and numerous engine screws and bolts. I've done it, been there and have the t shirt. I've been up on a stand trying to figure out how i'm gonna get a broke bolt out of an engine with a couple colonels, a major, a captain and several Cheifs on the ground wanting to knwo if I can fix it? Talk about pressure.
About broke, stripped, or otherwise stuck bolts. Let me break them into two groups. Let me call them heated areas and just plain corroded. Lets take heated areas first. Exhaust manifold bolts are a prime example. The area gets heated then cools etc, etc, etc. This causes corrosion and weakens the bolt.
Bolt removal in heated areas:
Step 1. clear the area as much as possible to make drilling easier.
Step 2. Grind/sand the broke bolt down flat and center punch as close to center as possible.
Step 3. Start with a small bit (split tip) say a 1/8th and drill as far as your can.
Note: keep chips cleaned, used compressed air or wd40 with the straw, or both, this is VERY important!
Step 4. keep drilling up in small incraments say 1/8" till you get to tap size. You can google tap drill sizes. Some tap drills are in numbers EX: 1/4-20 is a #3 drill bit
Step 5. begin tapping. You might only be able to turn the tap a 1/4 turn till you feel it get in a bind. back it all the way out, clean out the chips and do it again. Take your time!!!!
Step 6. Keep the chips cleaned out they are your enemy. Run the tap in and out by hand slowly.
Non heated areas............
Lets take those roll bar bolts for example.
Those torx heads will snap the end of a split tip drill bit off in a snap. Scrap one drill bit.
One way is to drill the torx bit starting with 1/8th then work your way up to say 3/16th then take a nice sharp chisel and pop the head off. Take channel locks and clamp the chisel in them.
Once the head is off follow proceedures for drilling and tapping in the heated section.
Drill bits: Get split tip drill bits. They are expensive but they are worth it.
When drilling remember....slow RPMs....heavy feed
EZ OUTs....... I don't like them. They cause more problems than what they are worth. They have an application but I havent found it yet.
I hope this helps yall. I actually typed all this and hit a button and delted it and retyped it again.
