Default Upgrading the yokes
Old 11-28-2011, 05:45 PM   #1
Modded Resident 'Old' Jeep Shaman
Images: 141
Rep Power: 5 BajaEdition is on a distinguished road
no not the jokes around here, your yokes.
I always wanted to write this but I found a picture Cj had posted in his tech article about breaking loose yoke nuts and decided to just go for it
here is the pic
here is the article
Easy Way to Remove a Yoke Nut. - Jeep-CJ Tech. Articles
so, if you run early Cjs you know of the really small U Joints we have and often times find they can be hard to source.
and if you are going do any diff work, then it can be time to swap these out for larger stronger more modern sizes.
but you have to swap out the yokes and get a new drive shaft.
that is not all that hard, I know a new shaft can cost money but the strength alone in the larger U joint is worth the money. As is the ability to change out a U joint quickly because you have the part right there.
I had mine swapped in my T case when I had it rebuilt and swapped out the ones on my diffs before measuring for a new shaft.
I then got the length of the shaft at full compression, at rest, and at full expansion and brought it to the drive shaft shop to have anew one made.
I used the size of U joint used in a TJ, I figure those would be easy to source for years to come.
New seals to stop leakage, and you are done.
anyway when finished I have a lot more faith in my U Joints than I had before the mods, and I bought the Yokes from my local Jeep shop.
Good luck, this one is worth doing and few guys think of it.
Owning a CJ is for manly men, they allows you to do manly stuff like auto mechanics and welding and drinking beer. Manly men own CJs. Manly men do not drive hummers, they receive them.
www.justgoodtrails.com
The Following 2 Users Say Thank You to BajaEdition For This Useful Post:
booneman (01-26-2012), JR74CJ5 (12-06-2011)
upgrading, yokes
upgrading to YJ style front leaf springs for the width j0114 Suspension and Steering 6 07-15-2011 01:10 PM
Upgrading Guages in CJ7 tireczar Misc CJ Discussion 11 07-11-2010 10:02 PM
Upgrading!! jwill22 Drivetrain 5 04-15-2010 09:41 PM
Upgrading Axle tycoon90 Suspension and Steering 7 05-24-2009 01:55 PM
