CJ Build ForumBuilding a CJ - chronicle it here! This forum is for build threads ONLY! Technical questions belong in the appropriate forum listed above.
Well here it goes boys
This is a discussion on Well here it goes boys within the CJ Build Forum forums, part of the CJ Forums category; Started to put the fly wheel back on and got the skid plate blasted and primed. Also blasted the Dana300. ...
Started to put the fly wheel back on and got the skid plate blasted and primed. Also blasted the Dana300. Have to clean out the inside better. It is amazing how much of the blast residue gets in even being taped off. I want to check the pilot bearing on the tranny shaft then install. took it to work to rebuild. I was going to let one of the mecs do it but I might give it a whril.
Life is to short to hunt with a ugly dog
The wife had surgery but is doing fine. Slowed the build down. Got the skid plate painted. Fnished the transfer case waiting for pionion nuts and a o ring for the speedo. Working on the tranny. Had trouble with the clutch because the resurface caused the bolt shoulders to bottom out and leave a gap between the clutch and fly wheel
