Default proportioning valve
Old 04-02-2011, 09:13 PM   #1
blaylock6502 is offline
Vehicle(s): 1974 cj5 currently in process of body off restoration and installing fiberglass tub
blaylock6502's Avatar
Rep Power: 8 blaylock6502 is on a distinguished road
I am in the middle of a 74 cj5 restore. I have finally gotten the tub back on the frame. When I went to mount the master cylinder to the firewall the brake lines were to short. the body mounts i fabricated lifted it about three inches. The question I have is there is what appears to be a proportioning valve inside the frame directly below the master cylinder and it does not appear to be factory and I was wondering what was supposed to be there. I was just going to make some longer brake lines line but at some point someone soldered together the brake lines because they are different sizes. I guess the point is im not really sure how to make this right. Any ideas?
Vote for daily!
Vote for
Default Re: proportioning valve
Old 04-03-2011, 10:02 AM   #2
73CJ is offline
73CJ's Avatar
Images: 61
Rep Power: 11 73CJ is on a distinguished road
A pic of the valve would help us figure it out with better accuracy.
Here's what should be there:
Old 04-03-2011, 10:33 AM   #3
BusaDave9 Admin
I would just make new brake lines. Get new hard brake lines. And some fittings. Put the fittings on the end of the line and use a flaring tool like this to flare the end of the line.
Then to bend the tube you need a bender like one of these:
What you have to keep in mind is all these fittings on your jeep are different sizes. They do that so that when you are replacing a part such as the master cylinder they don't want you to accidental connect the front brakes where the rear should be.
To make sure you get the correct sizes bring the proportioning valve to the parts store. You will also want to compare the master cylinder fittings so when you get to the store you have a good idea what size those are.
proportioning , valve
Proportioning Valve Question GatorBate Drivetrain 9 05-14-2013 12:18 PM
Proportioning valve question Wrangled13 Misc CJ Discussion 20 03-30-2013 04:43 PM
79 CJ5 Proportioning valve dochereford Misc CJ Discussion 4 04-12-2012 12:34 AM
Cleaning up proportioning valve ??? billyocup Chassis and Body 3 06-07-2011 01:46 PM
proportioning valve button escobar Suspension and Steering 3 02-13-2011 08:08 AM
Vote for
