Default 1983 CJ7 Mercedes Turbo Diesel Conversion
Old 11-20-2012, 10:45 PM   #1
DieselCJ is offline
DieselCJ
Vehicle(s): 1983 CJ7 3" Suspension Lift 2 Inch Body lift Fiberglass tub with hardtop and doors AMC20 and Dana30 D300 Tcase T4 Mercedes 5 cylinder turbo diesel
DieselCJ's Avatar
Rep Power: 0 DieselCJ is on a distinguished road
Hey there everyone, new here and new to the Jeep scene. I'm 18, and have been working on anything mechanical since I can remember. Learned from my dad, and then took it a step further and taught myself from reading forums, book, and anything I could get my hands on. It's my passion.
The Jeep was purchased a long time ago, along with the fiberglass tub, fiberglass tailgate, offy intake, holley carb and new springs, axle rebuild, poly mounts, ect. Unfortunately interest was lost, and it sat until this summer when I decided I wanted the old CJ to be mine.
I assembled the 258, got the tub on and cut out, axles under it, engine in, nutter bypass completed, tranny and tcase in, tank under it, ect. Got it to fire, discovered a million problems, and kept throwing money and parts at it until all of the broken stuff was replaced or rebuilt
Took it for a drive around the yard, parked it, and stood back: I didn't like what I saw. It was too common, everyone has a 258, carbed, intake/headers, blah blah blah
So out the 258 came for the final time, and in its place went a 1985 Mercedes 300D inline 5 cylinder turbo diesel (OM617). 20hp more than the 258, but due to having a short stroke and 3L of displacement it has 30ft/lbs less torque (more on this later.)
I made the mounts, wiring, controls, ect myself, and the engine to bellhousing adapter was sourced through merceded 4x4. The engine bolts right up to the t4 and uses the jeep flywheel, clutch, pressure plate, ect. I adapted the oil pressure sensor to the engine, along with water temp probe so the jeep sensors are also used. I got the glowplug wiring in, cooling system adapted, and oil pan notched. Started the engine, and all I can say is AWESOME
Final assembly followed. I opted for twin electric fans (3100CFM), an aluminum radiator, and a big 10 row oil cooler for the engine. It runs nice and cold. I've got a few hundred hours into the Cj so far, but it's worth it all! All done by me, and with all my own money.
I've licensed it, and took it out on the road, and this diesel has WAY more torque off the line and throughout the entire rpm range, a LOT more. It keeps pulling! The 258 must get it's numbers from some peak in the rpm curve. The CJ can really accelerate now. Still waiting on MPG numbers, and I need to regear from the 2.73's I currently have, which are way to tall for the 33's I have on it. 3.73's would be a lot better, but I'm broke so I have to roll with what I have for now.
I still need to build a rear bumper, tank skid, some exhaust stuff, get a new fuel gauge, seal some doors up and drive the wheels off it!
Let me know what you think! And thanks for reading!
Default Re: 1983 CJ7 Mercedes Turbo Diesel Conversion
Old 11-21-2012, 06:51 AM   #2
Images: 219
I think that @ 18 years young you do excelent work and have a great imagination!
You should be very proud of your CJ. I have a feeling that one piece axles will be in your very near future though...
Old 11-21-2012, 09:30 AM   #3
Rep Power: 14 gert is on a distinguished road
an 85 Mercedes Diesel WOW HELLA NICE WORK and your CJ looks great Welcome aboard
Old 11-21-2012, 10:23 AM   #4
DieselCJ is offline
DieselCJ
DieselCJ's Avatar
One piece axles and trussing are on the to-do list! A few says ago my dad BURIED his tractor in mud out in the woods and was convinced we'd need a bulldozer to pull it out. Mud was up to the axles, and the tractor had bottomed out on its belly. He said there was no way for me to get back there (a challenge right!?) I actually was able to crawl back between the trees, it was so narrow I had trees rubbing down both sides of the tub and top, mirrors were folded in. I was able to get a strap on him, and gave it everything I had, and amazingly pulled the 3000 some pound tractor out (with woodsplitter and loader on.) I was impressed! I actually was dragging him back until the ground was solid enough to get him up on land. Diesel saved a diesel!
Old 11-21-2012, 10:26 AM   #5
DieselCJ is offline
DieselCJ
DieselCJ's Avatar
First run: Mercedes OM617 5 Cylinder Turbo Diesel Jeep CJ7 Conversion - YouTube
Quick run down the road: Short Clip Of Mercedes Turbo Diesel Conversion CJ7 Jeep - YouTube
Walk around: Walk-around 5cyl Mercedes Turbo Diesel CJ7 Jeep Swap - YouTube
Old 11-21-2012, 11:51 AM   #6
Kilo19 is offline
Kilo19
Vehicle(s): 07 ford f-150 xl, auto, daily driver 98 chevy suburban, (family car)(SOLD) 2005 Ford Expedition 80 cj-5, body and frame
Kilo19's Avatar
Images: 15
Rep Power: 6 Kilo19 is on a distinguished road
awesome ride and amazing way to work a diesel in to the cj
:up:
check out my progress (slow and steady)
MY POS TO RUNNING/READY BUILD
Old 11-21-2012, 01:59 PM   #7
mtnwhlr is online now
Images: 56
Rep Power: 12 mtnwhlr is on a distinguished road
Good job on the Jeep I really like it you are wise beyond your years.
your not having fun until the dial 911
Old 11-21-2012, 07:25 PM   #8
diddy2003 is offline
diddy2003
Vehicle(s): 1984 CJ-7 35x12.5x15 MTRs; YJ 4 inch Skyjacker lift w/ Bilsteins; AMC 360, Patriot Headers, Holley Truck Avenger 670 CFM, Edelbrock Performer Intake, Flexalite Electric Fan; Dual Flowmaster Delta Flow 40s; Dana 30 4.10s w/ Detroit Truetrac; AMC 20 Welded Tubes 4.10s w/ Trac Lok; Superior One Piece Shafts; T-176; Dana 300 LoMax 4:1 Twin-Stick; Navajo Power Brake Booster
Rep Power: 8 diddy2003 is on a distinguished road
Woah, that is pretty cool! Definitely a different idea than most. Very nicely done. Have any 258 parts you want to get rid of?
Old 11-21-2012, 08:16 PM   #9
Images: 56
What are you looking for?
Old 11-21-2012, 11:15 PM   #10
diddy2003
I would be interested in the Offy intake if it will work with the Hedman header I just bought. If they are the same thickness where they mount to the engine. What else do you have? Send me a pm so I don't cludder your tread. Thanks.
1983 , cj7 , conversion , diesel , mercedes , turbo
1983 CJ7 Mercedes Turbo Diesel Conversion DieselCJ CJ Build Forum 0 11-20-2012 10:57 PM
Turbo 400 and BW 901? Hayden Drivetrain 0 04-11-2012 11:16 AM
turbo vs nos dalefan88 Sand, Dirt and Mud 17 10-22-2010 10:01 PM
Turbo - Yes Says I wrangler rider Drivetrain 4 12-29-2009 10:40 PM
crappy headlights?? h4 conversion or hid conversion biohazard cj Chassis and Body 6 12-14-2009 07:54 AM
