Default Re: 1973 CJ5. From rot to trail/hunting rig
Old 08-15-2012, 11:56 PM   #11
ThePunisher is offline
ThePunisher
Vehicle(s): 1973 CJ5, 304, 4.27 Dana 30 Front, 4.27 Dana 44 Rear, 2 1/2" Lift, 33x12.5x15 Pro Comp M/Ts
Rep Power: 6 ThePunisher is on a distinguished road
Got my 33s mounted today and slapped them on
Build Thread
Old 08-15-2012, 11:58 PM   #12
ThePunisher
And more pics of everything, all from today.
Build Thread
Old 08-16-2012, 12:17 AM   #13
tarry99 is offline
tarry99
Rep Power: 9 tarry99 is on a distinguished road
Looks Good............I don't see those rifle racks mounted in there yet..........Time is getting short.
Old 08-16-2012, 12:41 AM   #14
ThePunisher
I won't be using it this year unless I really rush everything haha
Build Thread
Old 08-16-2012, 10:01 PM   #15
mtnwhlr is online now
Images: 56
Rep Power: 12 mtnwhlr is on a distinguished road
The 33s look good on there.
The Following User Says Thank You to mtnwhlr For This Useful Post:
ThePunisher (08-16-2012)
Old 08-16-2012, 10:18 PM   #16
es335 is offline
es335
Vehicle(s): 1974 CJ5
es335's Avatar
Rep Power: 7 es335 is on a distinguished road
Quite a bit you have accomplished in a few weeks!!! Nice!
The Following User Says Thank You to es335 For This Useful Post:
Old 08-16-2012, 10:24 PM   #17
ThePunisher
Thanks guys. Not bad progress considering I've only been able to work on it about 4 hours a week. Once I get it trailered to my house instead of sitting in my parents driveway, A LOT more will get done even quicker. I have quite a few parts laying around waiting for that moment to come lol.
Next week I'll be looking at fabbing up my seat mounts and also working on the timing a little more. I have an idle vid but it's not uploading via youtube. Found out it has a big exhaust leak at the manifold collector. Just more reason to get a set of longtubes
Build Thread
Old 08-23-2012, 09:41 AM   #18
ThePunisher
Threw in a stock distributor with vac advance along with a new cap, rotor, points and condenser. Made a WORLD of difference in the way it runs. Smooth as a top now. Also picked up a new battery yesterday.
Tested the alternator and it's bad so I ordered a replacement, should be here tomorrow.
Went to fix my exhaust leak at the manifold collector and it looks like it's damaged pretty well so I tightened it up the best I could for now and it will have to wait until I order a set of headers.
And I drove it! Plopped in a 5 gallon bucket on the floor and put it in gear and drove it a few backwards a few feet and forwards a few feet. It wasn't a complete driveline functionality test because it has no brakes right now. I've everything to replace the entire brake system waiting to go on but haven't gotten there yet. She should be mechanically buttoned up in the next month or so then it's on to cosmetics
Build Thread
Old 09-13-2012, 10:19 PM   #19
ThePunisher
Got a good amount of work done over the last few weeks.
Fixed my oil leak by replacing the oil pressure line. It was plastic and it had a hole in it so I switched it over to copper.
Picked up the other half of my roll cage that matches the one that I already have.
Got a new bumper, mounted it and painted it. Started drilling my winch plate to mount it.
Did some sanding in some areas on the body and the roll cage that had collected a touch of rust.
Fixed my exhaust leak
Replaced my rear differential gasket
And yesterday I started to tear down the rear brakes, I had to beat the drums off which took about 2 hours. Everything inside was rusted and pretty much broken. Drums couldn't be turned so I had to order new ones too. Missing a few small brake parts that are on order then as soon as I get them I'll be slapping them on
Getting close to all of the mechanical items being done. Then I'll be going through all of the wiring and gauges. Then it's on to bodywork and paint!
Build Thread
Old 09-14-2012, 02:50 PM   #20
0822 is offline
0822
Vehicle(s): 1960 CJ-5 4 cylinder Dana 25 front Dana 44 rear factory Jeep metal top with steel doors. 1955 CJ-5 4 cylinder Dana 25 front Dana 44 rear. Warn overdrive
0822's Avatar
Rep Power: 8 0822 is on a distinguished road
Great looking project, keep the pictures coming.
1973 , cj5. , rig , rot , trail or hunting
Rust hunting advice KJs 83CJ7 Chassis and Body 8 10-28-2010 08:51 PM
New CJ5 Owner - Hunting Rig to Beach Cruiser gonfst Introductions 3 06-07-2010 12:38 PM
Elk Hunting CoreyYoungCj577 Outdoor Related 30 01-11-2010 06:27 PM
Hunting for a Jeep manderson2228 Introductions 42 09-26-2009 03:55 PM
hunting and fishing CJ Jeep News and RSS feeds. 3 02-18-2009 04:48 PM
